Old 01-10-2008, 06:36 PM   #1
poorboy
poorboy's Avatar
Oil pressure line repair
When I removed the original motor the line was froze and twisted until it broke.Is there a way to put a new fitting on the end.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 01-10-2008, 07:22 PM   #2
wild one
Registered.........
wild one's Avatar
Re: Oil pressure line repair
The oil line should have a compression style fitting on both ends, so it should only be a mater of removing the damaged section then replacing the fitting. If the line has a long length (greater than 2-3 inches) damaged or is rusty/kinked/fubared any where else you should just run a new line.
Any competent local parts house or hardware store (I use Orchard Supply Hardware for this type of fitting) should be able to match up a replacement. Just being the old fitting or samle of the line with you.
Good Luck,
Pete
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 01-10-2008, 07:24 PM   #3
poorboy
poorboy's Avatar
That's kinda what I thought but wanted to make sure. Thanks for your help.
