01-10-2008, 09:08 PM | #1 |
Freeeeee Mason...
Headliners, Stock/Custom/Non Existant
Right now I have no headliner in my truck and it's looking pretty drab. I was debating on getting a black leather one made with a red bow tie in in to match my interior. Has anyone done something similar? I'd really like to see pics of all the different liners. Also, would the best way be to buy one and have it re-done, or have one custom made? Thanks in advance. You guys are great.
01-11-2008, 06:05 AM | #2 |
Re: Headliners, Stock/Custom/Non Existant
The factory headliners are easy to come by but not as easy to get up there. It's doable but have several hours set aside for the job and ask a lot of questions here.
01-11-2008, 08:54 AM | #3 |
Freeeeee Mason...
What are the problems associated with getting one up and mounted?
01-11-2008, 09:09 AM | #4 |
The connecting tabs have to be broken off of the plastic trim because your cab won't have the little slots in the roof. I used like 1/4 inch screws to hold mine up and then glued the headliner itself. You will have to build a brace to gold the headliner up while the glue is drying. Even with 1/4 inch screws you have to be careful in the corners to now go through the roof. It is very close.
01-11-2008, 09:13 AM | #5 |
Freeeeee Mason...
Then I think this is probably something I should have done before all the paint and body work was done. I think this is a mod that I'll put on hold for a while. Thanks for the input Mudder. You're always very helpful.
01-11-2008, 09:22 AM | #6 |
Here's mine.
Hook'em |
01-11-2008, 10:34 AM | #7 |
Mine was all done when I did it.........
01-11-2008, 11:07 AM | #8 |
why can't you just cut the slots?
01-11-2008, 03:57 PM | #9 |
cause the tourch will burn the paint or holes in your roof!! serously i think it would be nearly imposable even with a die grinder or dremal but i think you could glue it with contact cement and just screw the trim on. i used spray adhesive and it held fine then i put the trim on, but i had the slots already
common sense isn't so common anymore |
01-11-2008, 05:26 PM | #10 |
I have added the headliner slots on 2 of my trucks now. I drilled holes at each end of the slots and then used cutoff wheel to finish off the slot. It was alot of work to get them in just the right location. I ended up cutting out the inner roof panel in an old cab with the slots already there to press up and use as a template.
01-11-2008, 06:09 PM | #11 |
I used 3M double face tape on the headliner and trim.... I removed the tabs from the trim first of course... It hasnt moved or fallen yet...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile Last edited by c10addict; 01-11-2008 at 06:10 PM. |
