Old 01-11-2008, 03:55 AM   #1
rckendal
cab supports
Starting to put my 72 jimmy back together, im in need of front cab supports, where can i get these, i have seen the slip on but i would like replacements, also is blazer/jimmy cab supports the same as for trucks. Also wanted to see pics of custom rear floors as Im wanted to do something different than metal. Thanks for any help.
rckendal is offline   Reply With Quote
Old 01-11-2008, 04:18 AM   #2
1969K10
1969K10's Avatar
Re: cab supports
There's a couple of vendors on the board that could help. GMCPaul I think is one. Then there's always LMC.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-11-2008, 05:38 AM   #3
jaros44sr
jaros44sr's Avatar
Re: cab supports
Give Tri-Pro a call, nice guy. They are located in NJ.1-866-754-9112, Jon can tell you of the closest distributor to you, it may well be Tim at Christians. I've used his stuff thruout and had no problems. Truck and Blazer/Jimmy are the same... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-11-2008, 06:22 AM   #4
vtblazer
vtblazer's Avatar
Re: cab supports
X2 on using Tri-Pro.
Just received 2 rockers/inners and both floor pans and they look right and seem to be fairly heavy gauge metal.
vtblazer is offline   Reply With Quote
Old 01-11-2008, 06:31 AM   #5
jaros44sr
jaros44sr's Avatar
Re: cab supports
When I was over there 3 weeks ago, I picked up a lot of body panels. All of them were of the highest quality, and heaviest gauge metal in the industry. Jon assured me that GM would not allow junk to be reproduced with GMC's name on it. All parts are reproduced to GM specs.
SAFETY FIRST
AS usual, off topic
Jim
