Old 01-11-2008, 05:56 AM   #1
bigjohn7372
bigjohn7372's Avatar
fuel tanks grommet
Can you replace the gromet near the fuel cap without removing the tank? Maybe cut the old one off and heat up a new one and slip it on? Mine is really dry and cracked. Thanks
bigjohn7372 is offline   Reply With Quote
Old 01-11-2008, 06:16 AM   #2
vtblazer
vtblazer's Avatar
Re: fuel tanks grommet
Yes you can but it's a PITA.
Go easy, work slow and watch the paint.
vtblazer is offline   Reply With Quote
Old 01-11-2008, 06:55 AM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
yes.......almost as easy just to take the tank out........NOW...try to find a GM gasket or an NOS or something other than what everyone else sells. I have tried several from several vendors and every one developed smalll cracks after a few months. JUNK!!!!
I have done it in warm weather, cold weather and had the same results.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 01-11-2008, 07:12 AM   #4
bigjohn7372
Thanks for the info. What grommet did you have luck with? Do you have a part number or a good aftermarket company? I've been using lmc.
Old 01-11-2008, 10:16 AM   #5
72freak
72freak's Avatar
Just find a GM one if you can...It will be in a GM bag....I dont have a part #.
That probably wont be an easy task.
Old 01-11-2008, 03:35 PM   #6
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
on mine I disconneted the hose's to the tank sprayed some soapy water around the old grommet (make sure none goes in the tank )cut it from the inside with pair of dikes pulled it off ...cleaned around the the area applied a little spray wax around new one slipped it in ....
JOHNORO is offline   Reply With Quote
