01-11-2008, 07:18 AM | #1 |
New LT-1 parts F/S
I've have several extra LT-1 parts left over from my 48 5 Window that I recently sold.
Like new CS130 alternator (<500 miles) new water pump new power steering pump with aluminum pulley Set of high mount Alan grove LT-1 brackets (Alternator and AC) Miscellaneous gaskets and fittings I would like to sell as a package, but might separate. $300 o.b.o. + shipping for everything. I also have a Carolina Rodshop fiberglass cover that was designed to cover up the throttle body and fuel rails on the LT-1. **** Cover SOLD to KHOULT pending payment. **** Thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-12-2008 at 08:07 AM. |
01-11-2008, 07:20 AM | #2 |
New LT-1 Parts
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-11-2008, 10:00 AM | #3 |
Re: New LT-1 parts F/S
Rob,
I might be interested in the AC mount, if u decide to seperate. i need to mount my A/c compressor so it clears the frame.
01-11-2008, 10:02 AM | #4 |
i also need the air filter box for the Lt1 set up.
i have the top half.. need the lower half
01-11-2008, 10:17 AM | #5 |
The a/c and alt brackets have to be run together, you can't mount one or the other. How about a deal on all of it?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-11-2008 at 10:19 AM. |
01-11-2008, 10:33 AM | #6 |
I don't know my chevy nomenclature much, but I'm assuming this won't work on the up to 86 small block right?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
01-11-2008, 03:16 PM | #7 |
It will bolt up, but getting everything to line up would probably take some engineering.
01-11-2008, 03:50 PM | #8 |
i'll take the cover.
01-13-2008, 06:00 AM | #9 |
01-14-2008, 11:14 AM | #10 |
bump
01-14-2008, 02:17 PM | #11 |
Crew Cut
i may need the other parts, sending pm
just make me a deal on everything you have left, what air compressor does it take ? do you have one? remember i am a poor boy from alabama
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK Last edited by OJOE; 01-14-2008 at 03:04 PM. |
01-16-2008, 01:56 PM | #12 | |
SOLD!!! to OJOE
