Old 01-11-2008, 08:49 AM   #1
65 on 24's
65 on 24's's Avatar
? about lowering
ok i got a 65 c-10 thats got 295/35/24 on it and im wanting to lower it i was going to use jeep spring in the back and i was going to cut the frunt ones any one no about how much to lower the frunt and how much the jeep spring will lower it in the back.i want to go low as i can and still trun. here some pics.
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 01-11-2008, 09:36 AM   #2
SIR
SIR
SIR's Avatar
Re: ? about lowering
...imho, your going to have a tough time trying to stuff all that "bling" under your truck without serious modifacations to all four corners and lots more $$$$......good luck.
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 01-11-2008, 10:07 AM   #3
badriand
badriand's Avatar
Just by looking at the bottom pic you may be able to bring the front down 1 to 2 inches without mods. I wouldn't recommend cutting the springs. Can't really tell on the back. I think most guys that run 20's or such have to cut fender wheels out and notch the frame quite a bit. Maybe of of those guys will chime in. You might be able to jack the rear end up a bit without the bed lifting to much and see how much travel you have between your tires to the fender wheels and rear end to give you a better idea on the back.
badriand is offline   Reply With Quote
Old 01-11-2008, 11:58 AM   #4
62ChevyStep
62ChevyStep's Avatar
65', I'm running 295/40/20 on the front and 295/45/20 out back, I was able to go a 3.5 /5 drop on mine, no CNotch, just spindles and spring up front and springs out back.
do rear clear the fenderlip? you might need to trim, to tuck. same question for the front, hard to tell by the angle of the pic.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 01-11-2008, 01:24 PM   #5
nonos64
im runnin 22's with bags but you look like you should go with 2.5" drop spindles and three inch drop springs in back and you should be able to still drive the spindles r about $300 and the springs are for the rear are $120, but you should go with spindles so you keep your tires from wearing on the sides fast but if you really want to do something get a dropmember front system and kp components rear system and lay that thing on the ground man on big wheels thats bad, later man but measure the distance between your front tire and fenderwell that should tell you a number of what you can go with before you start running into fender. http://67-72chevytrucks.com/vboard/a...1&d=1200072126
nonos64 is offline   Reply With Quote
Old 01-11-2008, 02:37 PM   #6
65 on 24's
65 on 24's's Avatar
yes they clear i got the right off set when i order them
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-11-2008, 02:40 PM   #7
65 on 24's
65 on 24's's Avatar
and i cant bag it i have my reason
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-11-2008, 03:21 PM   #8
Dinos63
chevy only
Dinos63's Avatar
truck looks good with big rollers,but with that off set wheel.....hmmm tough to lower much. my truck 20S and 22S
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-12-2008, 05:05 AM   #9
65 on 24's
65 on 24's's Avatar
im thinkin about 2 1/2 in frunt and 3 1/2 or 4 in the back. i no im going to have to get a new track bar i was going to for the new one for the disk brake rear end i put in
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-12-2008, 06:00 AM   #10
six4flat
six4flat's Avatar
the jeep springs will drop it 4" in the back
six4flat is offline   Reply With Quote
Old 01-12-2008, 06:26 AM   #11
65 on 24's
65 on 24's's Avatar
that cool
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-16-2008, 01:04 PM   #12
harbourmicah
harbourmicah's Avatar
if you want to cut them, not recommended, i think every half coil you cut off is about an inch of drop.
1966 chevy short step- under construction
http://www.fquick.com/harbourmicah
harbourmicah is offline   Reply With Quote
Old 01-19-2008, 07:28 AM   #13
65 on 24's
65 on 24's's Avatar
what jeep springs is every one usein cuz when i have call every one like, i need to no what they come out of
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-19-2008, 07:31 AM   #14
65 on 24's
65 on 24's's Avatar
what about this?
http://cgi.ebay.com/ebaymotors/JEEP-...em290197765858
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-19-2008, 12:02 PM   #15
65 on 24's
65 on 24's's Avatar
any one
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-19-2008, 12:29 PM   #16
Dadsredwagon
Dadsredwagon's Avatar
I hear rear Jeep TJ Wrangler springs.
Dadsredwagon is offline   Reply With Quote
Old 01-19-2008, 02:52 PM   #17
63fleetside
63fleetside's Avatar
dude just buy a set of gspp.com $110 5 inch drop springs
63fleetside is offline   Reply With Quote
