01-11-2008, 10:05 AM | #1 |
Junior Member
Tranny ?
Just had the T350 in the 69 built and installed. If you are going say 45mph and put your foot in it the engine rev's up before it transfers the power to the tranny. Is this a kickdown issue? Hope you can understand my description.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-11-2008, 11:25 AM | #2 |
its all about the +6 inches
Re: Tranny ?
Sounds more like a slipping issue... you checked the fluid level since driving it?
Engine and tranny warm (not hot like after freeway cruising or towing... just run it around the block a few times driving like a normal person) Parked on level ground, engine running, go through all gear selections, pausing at each one, then the same thing headed back up to park, then pull the dipstick, wipe, reinsert it, and look at the level. |
01-11-2008, 11:34 AM | #3 | |
Junior Member
Re: Tranny ?
01-11-2008, 12:31 PM | #4 |
Re: Tranny ?
well, it is not an instant thing... it does take a monent... but less than a second on a fresh tranny I would say.
01-11-2008, 01:33 PM | #5 |
Re: Tranny ?
What stall and gears are you running?
01-11-2008, 03:33 PM | #6 |
Re: Tranny ?
i would check the fluid level then drive it back to who did the rebuild and instalation and have them drive it if your not happy with it
common sense isn't so common anymore |
