Old 01-11-2008, 12:11 PM   #1
blockinnovations
How much does frame stick out from below rocker?
How much does the frame stick out from below the bottom of the rocker?
Same question as if the frame's laying on the ground, how high would the bottom of the rocker be off the ground? 1" maybe?
I'm drawing out a frame to bag my 1968, but I'm using 4" x 2" and realized that the rockers will probably be destroyed before the frame even touches the ground.
Also, anyone know how tall of a tire the front will take before it won't fit under the hood when truck's on the ground? Like, 30" or is it more like 29"
Thanks for your consideration!
blockinnovations is offline   Reply With Quote
Old 01-11-2008, 01:02 PM   #2
john
member #16
john's Avatar
Re: How much does frame stick out from below rocker?
to the board. You can get your answers in the suspension section. Alot of info and knowledgable guys.
http://67-72chevytrucks.com/vboard/f...splay.php?f=25
john is offline   Reply With Quote
Old 01-11-2008, 01:31 PM   #3
67cst
i love summertime
67cst's Avatar
the frame is roughly tucked up an inch higher then the bottom of the rocker on my truck..hope this helps
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-11-2008, 01:32 PM   #4
67cst
i love summertime
67cst's Avatar
as for your other question do a search, i was reading a thread about a guy who is doing some wild mods to his bagged truck and he mentioned something about o.d front tires and touching his hood, it should help you
