Old 01-11-2008, 01:05 PM   #1
Jvan
14 bolt corporate axles for 1st gen blazer
I've come across a local sale in Craig's list for the front and rear axles from a 85 suburban 3/4 ton. The ratio is 3.73. He's asking $200. Is that a fair price and would they swap into a 1st gen 72 Blazer. I don't know if they have positraction or not and the they look alittle rusted on the shafts but I've only seen a picture. What should I look for and avoid? I'm getting parts to do a restoration so this is not a must have but a stronger upgrade for the future.
Jvan is offline   Reply With Quote
Old 01-11-2008, 01:07 PM   #2
Jvan
Old 01-11-2008, 02:00 PM   #3
DieselEater
DieselEater's Avatar
Re: 14 bolt corporate axles for 1st gen blazer
great price for both!!! You'll have to relocate the spring perches on the rear end to work on a 72.
A......
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 01-11-2008, 02:01 PM   #4
LONGHAIR
Just so you know, there is a "what's it worth" forum just for things like this, but it is fairly new, so I will leave this here, for now at least.
As to your questions
If it is $200 for the pair, it is probably a good deal, reguardless of condition (unless they are really destroyed)
Things to look for:
Anything "loose" ... ball-joints, tie-rods, axle-joints, wheel bearings, etc.
Are they complete? brake parts etc.
Lock-out hubs? or automatics?
Look at the wheel studs
Leaks?
Look at the yokes
Can you take the covers off to look at the gears?
If the rear has a "factory" posi....don't look at it as a bonus. Do NOT pay any extra for it. If you can open and look, do so. If the "factory posi" is already damaged, it will be fairly obvious. When they go bad, there will be small parts floating around and a visual inspection will show the broken stuff. You don't even really need to know what you are looking for....it should be that obvious. It is possible that it is not hurt. With a stock engine, stock-sized tires, and fairly normal driving they can survive. That is about it though, they won't stand much more than that. If it is not destroyed, it may be worth buying, but like I said, don't pay any extra for it.
Just realize that you will probably have to put some money in them to get them under your truck.
LONGHAIR is offline   Reply With Quote
Old 01-11-2008, 02:35 PM   #5
Jvan
Didn't realize that there is a forum for "what it's worth" I'll try to get a look at them this weekend. The guy seems desperate to get them out of "his mother's backyard". Thanks for the list of things to check and the info on the posi. I'don't know how complete they are and I didn't think of asking. Good point to consider. I have 6 lugs now. Are 3/4 ton axles 6 or 8 lugs and if their 8 lug, can they be changed to 6 lug or should I leave them?
Old 01-11-2008, 02:47 PM   #6
1969 GMC
1969 GMC's Avatar
If it is stock, it is most likely a semifloating 14 bolt rear, and a 10 bolt front. I would keep looking.
3/4 ton will be 8 lug.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-12-2008, 05:28 AM   #7
Yukon Jack
Yukon Jack's Avatar
I put 3/4 ton axles from a 78 truck into my 70 K5. The front axle was the Dana 44 and the rear was the 14 bolt full floater.
I had to use a conversion u-joint to connect the rear axle. I positioned the axle as close to centered in my wheel well and did have my rear driveshaft lenght changed. I replaced the rear hard brake lines and used a new rubber line for the 78 axle. I did move the spring perches and relocated the shock mounts.
For the front Dana 44 3/4 ton axle, it bolted right in. My hard brake lines would not fit the 78's new replacement rubber hoses. As I was going to have to use adapters at my brake booster (I swapped in the 78's master) and at the place where the hard meets the rubber, I went ahead and just made all new front hard lines to avoid having adapters at both ends.
Here is a thread that has a bunch of details and pics of my project and the axle swap.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-12-2008, 03:01 PM   #8
Jvan
Thanks Yukon Jack, the link is a big help. I'll look at them this weekend and this thread has been a great help.
Longhair, where is the "what's it worth' site. I looked but couldn't find it.
