Old 01-11-2008, 02:04 PM   #1
SactoJim
SactoJim's Avatar
To difficult to run wire?
Wanna run a wire from right above rear view mirror (inside roof cavity) to pass side piller and exit just below the dash.
Can this be done or am I opening up a can of frustration in attempting this?
Tried running it under the window rubber, but it holds the rubber out just enough to bug me.
This is for a amplified antenna cuz I shaved the factory one. They just don't work very well when mounted under the dash or surround by metal and it works best on the window.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 01-11-2008, 02:20 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: To difficult to run wire?
Can't be done without major surgery. You can't even access the windshield pillars where they meet the roof. I believe they are sealed off. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-11-2008, 02:25 PM   #3
jbarron
Have you thought about mounting it on the rear window?
jbarron is offline   Reply With Quote
Old 01-11-2008, 02:42 PM   #4
corn
Run it up inside the rear "pillar". Easy access & a lot of room.
corn is offline   Reply With Quote
Old 01-11-2008, 02:51 PM   #5
SactoJim
SactoJim's Avatar
I thought that might be the case.
The best part about mounting it at the top of the front window is you really can't see it from the outside (shaded glass). The rear would be more obvious.
I was just looking at it and that may be the way to go....THX!
- supercharged 383
- 4 wheel discs
My Build Thread
Old 01-11-2008, 05:02 PM   #6
aventur1
aventur1's Avatar
To add another question---So how would you run the wire to the back piller and down? Let's say I wanted to put in a mirror with temp, N,W,S,E, etc. How do you do this? A thin wire and keep pushing it that direction and hope it goes down the piller? Then pull your wires back?
aventur1 is offline   Reply With Quote
Old 01-11-2008, 05:24 PM   #7
Sweet72
Sweet72's Avatar
The inner cab roof has a welded seam 6 or so inches above the rear window, so you won't be able to fish a wire through there either. Dark tint on the back window and install it there and run down behind the seat and follow the dome light/fuel sending unit wires under the drivers door sill plate, under mat/carpet to the dash area. Just realized were talking about a coaxial cable and it may be too fat to run with those other wires. I'm sure you'll find a solution.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-11-2008, 05:54 PM   #8
68C15
blood type; Retumbo
68C15's Avatar
what if you tied a washer to some light string and used a strong magnet to guide it through from the inside of the pillar? then use the string to fish the wire back.
68C15 is offline   Reply With Quote
Old 01-11-2008, 06:16 PM   #9
SactoJim
SactoJim's Avatar
Bummer!......back to plan "A".....whatever that was!
I didn't think about that back seam......makes sense.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 01-11-2008, 10:17 PM   #10
72armyswbtruck
72armyswbtruck's Avatar
Wes, that is exactly how I removed the 3/4 ton, 1ton cab lights wiring run down to the driver side pillar and exit by the e-brake.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 01-12-2008, 03:07 AM   #11
70GMCer
70GMCer's Avatar
Did mine without any problems, but you will need to use a headliner. This is done before the headliner is installed.
I went up inside rear driver side pillar behind the seat with a piece of 16 ga. copper wire and came out at the dome light opening (this is the area that the factory dome light wiring runs). This will be used for pulling the strand wire back to the fuse box. I then had to drill a 5/16" hole above the dome light opening, but just passed where the headliner will cover it. I then passed the 18/6 ga. copper strand wire along roof where the headliner will cover it. In other words, when finished, the wire will be ran between the headliner & inside roof panel.
Now right before where the mirror bracket mounts, I then drilled another hole for the wire to go into. Again, this will be covered up by the headliner. The wire will then come threw the opening where the mirror bracket attaches to and will be covered up with the bracket cover when finished. Allow enough wire to be ran from the mirror area back to the dome light area and down and along the sill to the fuse box area.
I hope this makes since. Here are 2 pictures of the finished work. In my case, I ran the extra wire count for adding any other features later on. Also, I used the later model mirror that mounts to the windshield and used flex tube to cover the wiring for the auto dim and map lights.
If you are not using a headliner, forget this mod. I don't believe the wire can be fished between the roof and roof liner panel. I tried and couldn't get it.
Hope this helps......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-12-2008, 03:23 AM   #12
aventur1
aventur1's Avatar
70GMCer
Good idea, I like that of leaving the stock mirror pad!!! Is that a red light on top center? What's it for?
Old 01-12-2008, 05:59 AM   #13
Frizzle Fry
Frizzle Fry's Avatar
I ran wires through both my A-Pillars, but the Burbs have a removable headliner instead of the metal inner roof skin making life MUCH easier.
Burbs have wires running up the driver's A-Pillar from the factory (tail/brake lights) with a gromet in the upper DS kick panel.
I don't see why it couldn't be done on a truck if you are willing to make an access point that can later be closed/covered.
The A pillars have two "passages." I found that the wires must be run in the FWD of the two passages. At least that seemed to be the case for mine.
Frizzle Fry is offline   Reply With Quote
Old 01-12-2008, 09:36 AM   #14
68gmsee
Active Member
68gmsee's Avatar
I think before I gave up on the idea, I'd try some electricians fish wire and probe the cab top through the holes where the window shades mount.
I just don't see where GM went to the trouble of adding blocking to the pillars. I may be wrong though...
68gmsee is offline   Reply With Quote
Old 01-12-2008, 10:26 AM   #15
70GMCer
70GMCer's Avatar
I too tried the fish tape......good luck.....
1997 GMC Sierra Ext
1965 Mustang
Old 01-12-2008, 07:05 PM   #16
68K20 x Drill
Easy! Just reach in through the rust hole.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 01-12-2008, 09:01 PM   #17
TravisH
TravisH's Avatar
On my 72 theres a about a 3/8" hole in the seam center of the dome light, thats how I plan to run my wires. If theres not borrow a 90* drill and use a short bit to make one. Stuff a grommet in the hole and call it golden
TravisH is offline   Reply With Quote
Old 01-13-2008, 05:30 AM   #18
71tahoe
71tahoe's Avatar
Ever watch American Chopper? When they have to run wire through the bike frame they use a kite string or similar and use an air blower attachment to blow it through the passage.
71tahoe is offline   Reply With Quote
Old 01-13-2008, 06:57 AM   #19
c10addict
c10addict's Avatar
I shaved my factory antenna too but what I did was took a regular stick antenna and bent the antenna mast 90 deg right above where it screws on to the base. I then drilled and mounted it in the cowl of the cab itself right around where the factory antenna was mounted in the bolt on cowl. Then I just bolted the wiper cowl on and the antenna is under it running the length of the firewall. It works great... Picks up plenty of reception through all the vents cut in the bolt on cowl and nobody has ever seen it to comment on it.. I did use the rubber seal agianst the cab with a bead of silicone to seal it from any possible water leaks...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
