Old 01-11-2008, 05:46 PM   #1
BLUE THUNDER
BLUE THUNDER's Avatar
lift springs
I was wondering if anyone on the board has used the tuff country 6" spring kit? I know that this topic is brought up all the time, but I'd like to do a little research on the springs befor I buy. BTW, I have a double wall top if it makes a difference. I pladn to drive it on the road most of the time. Don't get me wrong, I'm not afraid to use it off road. Thanks, Mario.
BLUE THUNDER is offline   Reply With Quote
Old 01-12-2008, 01:13 AM   #2
vtblazer
vtblazer's Avatar
Re: lift springs
Can't recall which company it was but one of the major lift spring manufacturers uses recycled metal for their springs and after a relatively short time they begin to sag.
Check the 4x4 tech section, there's always spring and lift questions and answer in there.
What size tires are you going to run with the lift?
vtblazer is offline   Reply With Quote
Old 01-12-2008, 04:56 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: lift springs
I've got Tuff Country 6" HD springs on my K20. I think the heavy duty extra leaf made the springs more in the neighborhood of 7". The springs don't seem to ride any different with the bbc compared to the prior 4" EZ ride springs when I had the sbc.
Both sets can get a bit bouncy on certain sections of a road that I drive, but generally I think they ride very well.
My K5 has Skyjacker 4" springs and the two vehicles ride surprisingly similar even though one has a 4" lift springs and the other has the 6-7" springs.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-12-2008, 02:55 PM   #4
BLUE THUNDER
Re: lift springs
Thanks guys.
Old 01-12-2008, 05:18 PM   #5
AJs72K5
AJs72K5's Avatar
Re: lift springs
My Alcans shipped on Monday. Once I get them on the truck, I'll tell you all about them.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 01-12-2008, 05:24 PM   #6
BLUE THUNDER
Re: lift springs
Sweet. I've been thinking of a Texas K5 meet. What do you think? If weather permits, I was thinking of early February. Maybe at a park so we can bar-b-que. Rudy's doesn't sound bad either. Let me know what you think. Later. Mario.
Old 01-12-2008, 05:30 PM   #7
AJs72K5
AJs72K5's Avatar
Re: lift springs
I'm probably out until late February. All of my parts should arrive in another week or two, then need to schedule a wrench-a-thon weekend with my guys at the garage.
- AJ
Old 01-12-2008, 05:39 PM   #8
BLUE THUNDER
Re: lift springs
Dude, I just talked (posted)to Richard 72Levi, and came up with The South Texas Blazer Invasion. Late Feb might work out too. I'll take a count on a new thread. Mario.
Old 01-13-2008, 05:55 AM   #9
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: lift springs
I think it should be called the BM "Blazer Movement"
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 01-13-2008, 08:36 AM   #10
Critter
Future TOTM Winner
Critter's Avatar
Re: lift springs
Good idea, Actually I think I am going to start calling your blazer the "B.M." Blazer Invasion would be pretty cool!
Anyway, I'm about to tear down and do some work as well. Late Feb would probably be better for me...not cause I am doing a lot...just cause I'm slow!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 01-17-2008, 12:58 PM   #11
myblazer72
Re: lift springs
I have the Tuff Counrty EZ ride springs (6"). They have about 20,000 on them now and they are a bit more tame then before. But I will warn you if you hit a bump in the road going at a good rate you will definetly get the front end up. I would have opted for a little less bouncy ride but I didn't do the research four years ago. I wanted to level the truck out and put the ORD add a leafs under them, so with the hard top on it sits right. I keep the soft top on most of the time and it doesn't ride high.
72 K5/350/700r/205
6"front/7" rear-15-10 Welds/35s
STC Top
MasterCraft front seats-Factory Back
Lookin for paint
myblazer72 is offline   Reply With Quote
Old 01-17-2008, 03:34 PM   #12
BLUE THUNDER
Re: lift springs
I've heard that the Skyjacker ez ride are really good. Then again, it was a salesman who told me. Anyone have first -hand knowledge?
Old 01-17-2008, 06:01 PM   #13
AJs72K5
AJs72K5's Avatar
Re: lift springs
Have you been talking to the counter guys at 4WP ? They told me the same thing! 6" Tuff Country and Skyjacker were fairly close to each other in spring rate. If you don't want to shell out big $$ to get some made, you may want to look at the 4" Tuff Country's (Offroad Design) with some Offroad Design Zero rates. That'll net you 5" of lift with a decent ride. The 4" Tuff Country's by far had the softest spring rate of the off the shelf springs when I was researching.
All of that being said, my full set of Alcans was about $950 shipped. Pretty dang close to the price of Skyjackers from 4WP and custom made based on how you drive and what you drive to boot!
- AJ
Old 01-17-2008, 06:22 PM   #14
BLUE THUNDER
Re: lift springs
Yeah AJ, Whore Wheel Parts did tell me that. So you think Tough Country is alright? I mean I might be putting the carriage in front of the horse, thinking about a lift and it's not even running yet; but a little more altitude never hurt anybody.
Old 01-17-2008, 11:55 PM   #15
AJs72K5
AJs72K5's Avatar
Re: lift springs
My suggestion: get the engine swap done. Then start planning out what you want the stance to look like.
- AJ
Old 01-20-2008, 02:43 AM   #16
bigjohn7372
bigjohn7372's Avatar
Re: lift springs
I'd like to raise my blazer 2" to 3" just to get a little more space above my 33's. What's the least expensive way to do it? I've never attempted and suspension work before. I'd go higher but the garage is too small
bigjohn7372 is offline   Reply With Quote
Old 01-20-2008, 10:51 AM   #17
OLD SKOOL K5
Re: lift springs
I'm also going to lift my Blazer 4" and it seems the alcans would have the best ride quality for the price!
OLD SKOOL K5 is offline   Reply With Quote
Old 01-21-2008, 05:01 AM   #18
BLUE THUNDER
Re: lift springs
I think we'll have to go on a test drive in AJ's72 to see what the alcans feel like. Mario
