01-11-2008, 09:27 PM | #1 |
what do I need to swap TH350 to 700R4
What do I need to do to swap out my TH350 to a 700R4 in a lwb truck? The 700R4 is out of a 89 model.
01-12-2008, 03:12 AM | #2 |
Re: what do I need to swap TH350 to 700R4
Do a search. There's alot of write ups on this.
1997 GMC Sierra Ext 1965 Mustang |
01-12-2008, 04:28 AM | #3 |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-12-2008, 04:55 AM | #4 |
Trans, Driveshaft, dipstick, kickdown, move the crossmember back, converter, lock-up module if its a lock-up.
I think that is it.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
01-12-2008, 08:48 AM | #5 |
Unless you have a 4x4. Then you need an Advanced Adapters "700r4 in place of a th350 output shaft" and no crossmember changes. And you'll need to move your engine forward which means you need to work on your cooling fan. Or leave the engine where it is and lengthen the front driveshaft and shorten the rear.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
01-12-2008, 10:11 AM | #6 |
Parts and more parts
Is the 350 a long output shaft tube or a short output shaft tube? There were two different lengths over the years.
