The Older Generation
Re: trans cooler question
It kind of depends on the size. I have mounted them on the inside of the frame rail, bottom of the floor pan, front of the core support, and even under the running boards on the older cars. You want good air flow but just as important is to be protected from road debris.... Core support means longer lines but that is not all bad either. LockDoc
Put mine on outside frame rail on pass.side. It is about where drive shaft goes into tranny. Hose up and over frame attached to bed bottom. Did not want to clutter up front anymore.
Gary |
![]() Join Date: Nov 2004
Here's mine, totally hidden from view.
I put it on the front of the front frame crossmember. It just barely fit. It's as far to the DS as it could go. If I had used 90 degree fittings I could have centered it more, but I was cheap and used the "straight out" ones that came with it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-12-2008 at 11:42 AM. |
Chief Honcho In Charge
So if you add one of these with a TH350...does that mean you do not need to run the lines to the radiator?
That would be a nice thing. Tim
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) Last edited by timcos; 01-12-2008 at 03:15 PM. |
A-Adam A-Adam
Mine is in front of the radiator and behind the AC condensor.
70 3/4 ton GMC Camper Special |
Old member
I stuck mine between the condensor and the radiator. I also ran the lines to the internal coolier also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#8 | |
![]() I hadn't hooked mine up yet in the pic.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-13-2008 at 03:27 AM. |
