Old 01-12-2008, 10:29 AM   #1
LBJ
Replace Pan and Main Gasket - On Truck?
I have a pretty good engine oil leak right above the main cross member. Looks like the front main seal right under the timing chain cover. Can you get to and remove the oil pan while the engine is in the truck? I bought a one piece neoprene type gasket, but would like to know if it is doable before I set out on the replacement. Thanks, LBJ
LBJ is offline   Reply With Quote
Old 01-12-2008, 01:59 PM   #2
James McClure
One shot, one kill.
Re: Replace Pan and Main Gasket - On Truck?
LBJ: 2 wheel drive or 4? 2 wheel drive can be done in the truck but it ain't easy. 4 wheel drive is a piece of cake. If you replace the damper seal pay close attention to the condition of the hub on the damper. Over time and high mileage they get grooved and new seals start leaking almost right away. NAPA sells a "wear ring" you hammer on to the hub before you install it and it works great. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 01-12-2008, 04:45 PM   #3
LBJ
James McClure,
It's 2 wheel. The truck has around 80K miles, I suppose. Now, are you talking about just pulling the pan? Or more?
Old 01-12-2008, 05:49 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if memory serves me correct you have to unbolt the motor mounts and jack up the motor and stick 2X4s in there and let the motor down onto those to be able to drop the oil pan to replace the seals/ oilpan gasket.. I believe its tight too to get past the oil pickup but it is doable
its been years since i did this job on a 2wd truck so thats my best recollection
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-13-2008, 03:56 AM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I did it twice on my '86 C10. I didn't have to jack up the engine or anything. There was plenty of room to get it in and out.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-13-2008, 04:06 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
You "should" be able to get the pan off without jacking the motor. If you do need to raise the motor a bit, turn a 2x4 on it's side and put it under the damper to get a bit more room. Don't forget to watch the dizzy cap that it doesn't get smashed against the firewall.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-13-2008, 04:20 AM   #7
LBJ
Slonaker, Let me ask you something. Why did you do it twice? <grin>
Old 01-13-2008, 04:56 AM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: Replace Pan and Main Gasket - On Truck?
Like the other have said it can be done in the truck but the 1 piece seal won't work on your '77 block unless you have installed a newer block that uses the one piece seal.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-13-2008, 05:04 AM   #9
swb85
On a budget like Fred Sanford
swb85's Avatar
He's talking about the oil pan gasket, not the rear main.
There's plenty of room to do this, I've done it three times on my truck on two different motors. It's a piece of cake if you're comfy on your back.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-13-2008, 06:07 AM   #10
LBJ
So, now it seems I can't use the one piece pan gasket on my old block. Correct? The seal that's the worst is the front, but I suspect the rear is leaking too. Go the old way with individual seals for the front and rear mains, and separate pan gaskets?
Old 01-13-2008, 06:34 AM   #11
James McClure
One shot, one kill.
LBJ: Morning. This is just my opinion so take it for what it's worth. If it were my truck and I had multiple leaks, oil or coolant I would cut to the chase and just pull it out and reseal the whole thing and be done with it. Ya, it's more work in the short haul but in the long run you'll be better off. If it's high mileage and the age is getting up there check the frost plugs too. jim
Old 01-13-2008, 06:41 AM   #12
spudz
spudz's Avatar
If you got the time...ITS REALLY nice pulling the motor and putting it on a stand and resealing it.. Then you could clean and paint everything.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 01-13-2008, 07:07 AM   #13
swb85
swb85's Avatar
Yes you can use the one piece pan gasket on an old block. What 87 stepper was referring to was the rear main seal around the crankshaft which went to a one-piece design in the late 80's.
With the pan gasket, the front seal that goes between the timing cover and oil pan came in two different thicknesses. Make sure you get the right one. Yours should be the thick seal if I remember correctly. You'll know immediately when putting it on if it's right or not.
Old 01-13-2008, 08:27 AM   #14
Slonaker
Slonaker's Avatar
That's a long story....
My truck had what I think was a 305 crate motor in it rather than the original 305. The block had the bulge for the dipstick on both sides of the block and pan, but was only drilled for the dipstick on the passenger side. I installed a Fel-Pro stock '86 pan gasket, and found out that it doesn't seal the bulge on the driver's side because the bulge isn't supposed to be there. I lost a quart or two of oil just in a few miles of driving.
None of the local parts stores could find a part number for an oil pan gasket with the bulge on both sides that fits a block with a one piece rear main seal ('86 was the first year for the 1 piece rear main seal). No one on here knew what I needed, either. It was easy to find one for the two piece rear main seal engines because all of the crate engines (like the one I have now) are drilled for a dipstick on both sides, but no luck with mine.
I ended up having to go to the dealer, and they were able to use the part number on the pan to get a part number for the pan gasket. There was only one gasket available in San Antonio from one dealer, and it was almost $80. Ouch!
A few days later, the guy at my local O'Reilly said "Hey, I finally found the Fel-Pro number you need." It was a special order item, but only like $12 or so.
Slonaker
Stock '01 Silverado
Old 01-13-2008, 12:14 PM   #15
LBJ
I may delay this till warmer weather. It can change from 65 degres F like today, to 20 degrees in just a short time. I have to work out in the open driveway, so no protection from the cold wind or rain. I may end up pulling the engine out next Spring and doing some sealing up. The engine runs fine, but I hate to have leaks. Just bugs me. I did give a look at the clearances. Moving the trans cooler lines and fuel line out of the way and using an air ratchet, it may be possible to do it! It is difinitely leaking either from the pan or crankshaft seal on the timing chain cover. They are right on top of one another, so hard to tell exactly. I suppose that timing chain cover sould be done in place too, but would have to take off the accessories to get to it. Be worth it to get those leaks stopped. That might be a good time to change out the A/C seals since things would be out of the way.
By the way, I bought the one piece gasket that has the holes on both sides for the dip stick. May have to take it back to Auto Zone.
