01-12-2008, 10:57 AM | #1 |
Anyone with a mounted 315/35/20???
I need to know how tall the sidewall is when mounted on a rim.
Thanks |
01-12-2008, 11:00 AM | #2 |
Re: Anyone with a mounted 315/35/20???
I want 315s!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
01-12-2008, 11:16 AM | #3 |
Yeah you and me, I am going to run them but I need to know the sidewall height so I can pick out me a front tire. I don't want more sidewall on the front than I have on the rear.
01-12-2008, 12:22 PM | #4 |
315mm x 35%= sidewall in mm. then convert to inches.
Mike
Mike Redpath |
01-12-2008, 01:17 PM | #5 |
A guy with a truck
That tire is 28.68" tall. For a 20" front, use a 255/40-20 = 28.03" tall. For an 18" wheel 255/40-18 will be 26.03...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-12-2008, 02:28 PM | #6 |
So how tall is the side wall again? Thanks guys.
01-12-2008, 04:51 PM | #7 |
go here and you can plug in any size you like for specs.
http://www.rims-n-tires.com/info_specs.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
01-13-2008, 03:49 AM | #8 | |
Thanks |
01-13-2008, 04:28 AM | #9 |
The bad part is now finding a front tire to match the rear. I can get toyo proxes s/t in a 315 for $206 a piece but they don't have that tread in the 255.
01-13-2008, 06:27 AM | #10 |
I'm planning on running this size of tire too. Did you have to modifiy the wheel wells to get them to fit?
01-13-2008, 06:33 AM | #11 | |
01-13-2008, 06:39 AM | #12 |
Here is the tire size calculator that i use. It is the best one yet. You can compare two size of tires. It even tells you the difference the speedometer will be when you compare two tire sizes. From original to the new tire size. Its pretty sweet.
Josh ps. That is a big A$$ tire but i bet it will look sweet
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
01-13-2008, 07:19 AM | #13 | |
I'm going to splice 2 tubs together to get an extra inch or 2. |
01-13-2008, 07:46 AM | #14 |
01-13-2008, 08:05 AM | #15 | |
Mounted on what....
01-13-2008, 08:07 AM | #16 |
New Member
If you go to www.project33.com and then to calulations tool ,there is a tire size calulator there.Very cool site about a build on 33 ford coupe
01-13-2008, 09:04 AM | #17 |
01-13-2008, 03:21 PM | #18 | |
http://www.toyo.com/docs/tires/tires...=lgt-suv-truck A 315 isn't going to fit stock tubs on an 11" + wide wheel unless the truck isn't real low & the outer edge of the tire sits flush w/the fender lip (so no tuckin' tire). 295's on 10's would work w/the right BS, tight suspension, & consistent body-panel/chassis gapping.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-13-2008 at 03:25 PM. |
01-13-2008, 03:34 PM | #19 | |
01-13-2008, 03:49 PM | #20 | |
01-17-2008, 07:16 AM | #21 |
paper or plastic?
I run a 315/35/20 on the rear and a 245/40/20 up front. The front is just a hair shorter. The Treads dont match but it does bother me.
They are on my 86' with 12" wide wheels they fit with very little trimming.
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
