01-12-2008, 03:35 PM | #1 |
axle price?
Hey guys, what's the going price for a matching set of axles. 12 bolt and dana 44 with disc brake setup. I've got a guy who wants $500 just for the dana 44 which has new rotors and ball joints. Seems alittle steep. Thanks for any replies.
01-12-2008, 04:53 PM | #2 |
Re: axle price?
Brand new 8.5" 10 bolts from a CUCK (Army Blazer) can be had for $300 each with a Gov-Lok in the rear. But they come with 3.07 gears...
Personally, wouldn't take less than $500 for my 12 bolt. The thick gears were $200, the bearings were $150 (including axle bearings) brake drums were $65 apiece plus the new pinion yoke. Then there is the labor to set it up and the Eaton Posi(original, re-built with new springs/clutches/plates) Cost you a grand to duplicate it. $500 is steep for original axles, either end. I wouldn't pay more than $400 for the pair if they are all original with 3.07 gears. I'd give $100-$200 more for 3.73 or 4.10 especially if the original Eaton is in the rear. I bought a complete 3/4 ton 4x4 Suburban with 8.5" 10 bolt front with 4.10 gears and semi-float 14 with 4.10's and a Gov-Lok for $300. Both are stronger than the Dana 44/12 bolt combo. The front mostly because it has the larger u-joints which the 44 could be upgraded to.
01-12-2008, 06:48 PM | #3 |
Re: axle price?
There is a guy near here that regularly sells front or rear working axles for $100
To have a shop put in new ball joints will cost $400, and needing them is pretty likely.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
01-13-2008, 05:53 AM | #4 |
I'm a poor spectator
Re: axle price?
Ball joints are nothing, buy a cheap axle and put them in yourself, you can find d44's in yards for 150 or so and rears for as little as 75 bucks. Maybe Critter will chime in but IIRC he didn't pay more that 200 buck for all new stuff to rebuild his front axle, that doesn't include gears, however, just seals, ball joints, bearings, etc.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
01-13-2008, 09:23 AM | #5 | |
Future TOTM Winner
Re: axle price?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
01-13-2008, 11:17 AM | #6 |
Re: axle price?
'Tread Saver' brand ball joints are about $16 each, but I don't think I'd put one on my truck.
