Old 05-04-2002, 02:38 PM   #1
pappap
Post fan speeds
I only have high speed on heat/ac fan--where should I look to correct this problem?
pappap is offline   Reply With Quote
Old 05-04-2002, 02:40 PM   #2
Baradium
Binder Rep
Baradium's Avatar
Post
sounds like you have some corrosion you need to get rid of.
Baradium is offline   Reply With Quote
Old 05-04-2002, 04:03 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
thew low and medium fans resistance springs screwwe donto the top side of inside heatet box assembly need ot be checked out for burn and also swithc may be bad in the dash, the fan speed switch itself, inexpensive fix in either case ofrtunately
good luck
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad
-82 purple Trans Am, project #2
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
