Old 01-12-2008, 04:23 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Switching from rod to Cable on the gas pedal
Has anyone done this on a 1968?
The rod is giving me fits with the T350 kickdown cable and the carb linkage is not as good as it should be.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-12-2008, 04:34 PM   #2
fastom
That's right, it's Copper!!
fastom's Avatar
Re: Switching from rod to Cable on the gas pedal
Done it!! Using Lokar stuff, pedal and cables. It's easy to do and the products are nice.
fastom is offline   Reply With Quote
Old 01-12-2008, 05:55 PM   #3
skokie
skokie's Avatar
I like the Lokar!! Looks good.
Was it major or minor surgery to put that lokar in?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-12-2008, 08:12 PM   #4
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I put the Lokar throttle and kickdown cables on my truck... After screwing around for over an hour trying to get the GM kickdown cable to work with the Holley brackets I had, I gave in, spent the money on the Lokar stuff and had both cables installed in about an hour.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 01-12-2008, 09:06 PM   #5
smbrouss70
smbrouss70's Avatar
Putter did a FAQ thread using stock 72 parts. http://67-72chevytrucks.com/vboard/s...d.php?t=170383
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
