Old 01-13-2008, 08:19 AM   #1
lyrikz
PITbut
lyrikz's Avatar
Preventing warpage from welding?
Im currently installing my floor in my 71. I noticed that when i weld over 4 inches at a time, the floor tends to warp a bit.. Im not to worried about that because it will be covered in dynamat anyways, but i am concerned about when i do my patch panels.
What are ways to avoid warpage? Bucket of cold water with a rag? Tack weld the whole piece??
Any and all tips are appreciated...
lyrikz is offline   Reply With Quote
Old 01-13-2008, 08:28 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: Preventing warpage from welding?
Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac-Tac...
On flat areas anyway. Curved and bent areas are more tolerant to running small beads.
Frizzle Fry is offline   Reply With Quote
Old 01-13-2008, 08:33 AM   #3
68 short step
4" bead is just like asking "hello mr. panel will you please warp"... do like fizzle fry says and tack the whole thing in....that is the best, less destortion way to do it..
68 short step is offline   Reply With Quote
Old 01-13-2008, 08:42 AM   #4
David Flores
David Flores's Avatar
I learned the hard way and had to redo a panel. but yeah, tack tack tack, let it cool down some in between. It takes a lot longer but comes out 100x better.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 01-13-2008, 09:05 AM   #5
lyrikz
PITbut
lyrikz's Avatar
Bah, thats what i figured. ahaha.. That would take forever doing a floor pan.
Sidenote: Anyone else not getting email notifications anymore since the update. My email box is empty now. No goody messages from here anymore. Bummer man.
Old 01-13-2008, 09:37 AM   #6
cdowns
cdowns's Avatar
lots of small tacwelds do left middle right and keep alternating dont do all the tacwelds in a row
Old 01-13-2008, 09:48 AM   #7
tkeduk8r
tkeduk8r's Avatar
I space the tacks as far apart as possible when I first join the patch and panel, then split the distance between the first tacks with the next group and so on and so on until the seam is complete... In addition to that technique, the old timer at the body shop I used to work at used to immediately blow compressed air over the tacks as he placed them to cool the metal, and I NEVER saw him worp a panel... These two things have worked pretty good for me... I also use a weld seeting of .023 wire, 16Volts and 220-240 in/min wire feed speed if yoru using a MIG welder.... Good Luck!!!
--MIke
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
