Friday's Toy
![]() Join Date: Nov 2006
Turbo 400 rattles?
What would make a turbo 400 rattle at a stop light, but fine going down the road, fine in park and neutral? It doesn't really bother me because you can't hear it outside cause of the exhaust but I was wondering if I need to take care of this before it becomes a bigger problem. Thanks in advance, Michael.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me. 2009 Jeep Rubicon 2011 Powerstroke FX4 (totaled) 71 C10, SWB Fleet with factory tilt 72 LWB C10, 350 700R4 with factory tilt |
Re: Turbo 400 rattles?
Have you checked the flywheel cover to make sure it is secure? I ask this because I had the same problem and mine was loose.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Active Member
![]() Join Date: Jul 2007
Long time ago my brother had a noisy transmission. He found the flex plate/flywheel was cracked.
Check all the mounting bolts for any of them being loose or for any cracks. |
Have it checked out. If your tranny goes you are stuck.
if it was the flywheel it would make the noise in park or N, only making the noise in drive says to me something to do with it vibrating. maybe the exhaust or something near the tranny vibrating on it that sounds like its coming from it?
Friday's Toy
thats what makes me worried ... being stranded.
Friday's Toy
my pipes are very close to my crossmember
#8 | |
Active Member
Select, aside from that possibility, what engine do you have. Mine has a rattle when in idle coming from the heat riser on my 6 cylinder. But any loose metal can cause, this especially in idle if the engine has a rough idle. Most engines smooth out at higher speeds. Last edited by 68gmsee; 01-14-2008 at 05:12 AM. |
