Old 01-13-2008, 05:36 PM   #1
corn
do-it-yourself 69-70 inner grille?
Anyone made their own inner grille on a 69-70? Id like to have one & have been thinking about making one if it wouldnt look tacky too when its all said & done...
corn is offline   Reply With Quote
Old 01-13-2008, 07:55 PM   #2
Psycho71
Psycho71's Avatar
Re: do-it-yourself 69-70 inner grille?
I'd give it a shot. I picture some SS woven/welded wire. Maybe .375"-.5" hole size?
Could go perforated?
Or were you thinking about something more exotic?
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-13-2008, 08:22 PM   #3
corn
Not sure if I would just find a sheet of mesh or maybe have something laser cut at work. Still trying to decide but it wont be real flashy however I do it. Any ideas?
Old 01-14-2008, 02:52 AM   #4
What would it look like with no inner grille?The GMCs are open like that.
Old 01-14-2008, 04:59 AM   #5
68gmsee
Active Member
68gmsee's Avatar
That's an idea to consider. I never was too crazy with the flimsy plastic they used on the inner grill for these trucks.
The only problem with removing it is tha it leaves some larger than normal openings where you can see the radiator etc. I have both GMC and a Chevy and both of the grills are out at this time. I'll be keeping an eye out for any suggestions.
68gmsee is offline   Reply With Quote
Old 01-14-2008, 05:22 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I know that LMC has a billet insert for sale. The speed grille idea is interesting. I don't like (personally) the flame designs and such that are being offered and seen on late-model trucks, especially for the '69-70's as in insert.
I would like to see a billet insert that has vertical bars, instead of the horizontal ones, just for kicks. Maybe an egg-crate billet design would mimic the original plastic insert, yet be different. I know the cost of such would be much higher than a straight-bar billet insert. Tube grill insert, anyone? Maybe one done with 1/4-inch stainless bars would be different enough.
I have thought of painting my insert to coordinate it with my wheels and interior....red. Think of seeing a '32 Ford grille with the bars in red and the shell in black, with a thin stainless bead between the bars and the shell. Hey, it's just an idea.
Member Nr. 2770
Old 01-14-2008, 06:39 AM   #7
corn
Like this...
Old 01-14-2008, 06:43 AM   #8
corn
This is the basic plan I was thinking except maybe a bunch of bowties instead of squares.
Old 01-14-2008, 09:06 AM   #9
pmpski_1
pmpski_1's Avatar
That might look cool.
pmpski_1 is offline   Reply With Quote
Old 01-14-2008, 05:59 PM   #10
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
A locall guys cut the cooling fins off the back of a ole refrigerator and used in his grille looked pretty neat!!
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
