Old 01-13-2008, 06:30 PM   #1
MisterE72
Keep Your Nose Clean
Is the ECE 4 - 6 drop too low?
Hi all,
I currently have a 3.5 - 5 drop (2.5 spindle 1" coil/5 rear coil) set up ready to install on my truck. I thinking about running 20x8.5 front wheels (255/40/20 tires) and 20x9.5 (315/35/20tires) rears. I'm not looking to get too aggressive with the off set. Do you all think that a ECE 4-6 drop would put the truck so low that I may have tire rubbing or turning issues. I have an oppertunity to sell what I have now, but i'm not sure if I should. I'm aiming for a stance like the one pictured here. Throw in a picture if you are doing something like what i'm aiming for and a little advice if you can. Thanks.
MisterE72 is offline   Reply With Quote
Old 01-13-2008, 06:40 PM   #2
MisterE72
Re: Is the ECE 4 - 6 drop too low?
whoops, the pic exceeded the limits. Let me get another.
Old 01-13-2008, 06:44 PM   #3
whatnow123
whatnow123's Avatar
You will be fine with that on the front as I have the equivalent size front tires but 285 60 17 in the rear. The tire might be a bit wide on the back if you have a stepside as I have 1/2 inch to the bed side on mine. Not sure if fleetside gives more room. I have a 4 6 drop as well.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-13-2008, 06:55 PM   #4
MisterE72
It looks like you have good gas tanks clearance as well. I have the same tank set up.
