Old 01-13-2008, 06:54 PM   #1
**grumpy**
**grumpy**'s Avatar
Arrow Making my own front bag plates?
Just wondered if anyone has made their own front upper bag plates?
I know they aren't too expensive, but....
I'd like to make my own if it's possible.
Anyone do it? Any advice? Pics?
I'm on a tight budget, and was thinking........
**grumpy** is offline   Reply With Quote
Old 01-13-2008, 07:37 PM   #2
SCOTI
SCOTI's Avatar
Re: Making my own front bag plates?
Cardboard template of the bottom of the crossmember @ the spring pocket area. Make it out of 1/4" plate & use GRADE-8 3/8" bolts on 4 corners through the crossmember 'lip' to attach it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-14-2008, 04:07 AM   #3
7T2
Active Member
7T2's Avatar
www.***************** - these guys will probably make whatever you want for relatively cheap. Cheaper if they can sell it to somebody else in the future.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 01-14-2008, 04:58 AM   #4
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I agree with SCOTI. Pics of mine:
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 01-14-2008, 05:19 AM   #5
red02chevy
I have a set of SD.com and ART plates. Let me know if you'd like for me to take some pictures with measurements.
I think it would just be worth it to order the SD.com plates. They are fairly cheap.
red02chevy is offline   Reply With Quote
Old 03-13-2012, 02:03 PM   #6
blongmire
blongmire's Avatar
This may be a dumb question but in these pics it looks like yall cut away the stock bump stops off the lower control arm is this true and has anyone had steering issues after dropping this low with stock set up...
blongmire is offline   Reply With Quote
Old 03-13-2012, 04:04 PM   #7
SCOTI
SCOTI's Avatar
Yes the bumpstops are typically removed for bag clearance.
Yes, steering issues can arise @ 'dumped' or other heights vs where the alignment is done. They would be the same as a static drop @ ride height (since the alignment is done @ ride height).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
