Old 01-14-2008, 12:29 PM   #1
ErichK
Need help identifying truck
Hey guys,
Can anyone help me identify the year and model of this truck?
I attached some pictures.
Let me know if you need any more.
1991 4x4 Chevrolet Cheyenne - 350 Vortec/700r4 - Shortbed
ErichK is offline   Reply With Quote
Old 01-14-2008, 01:19 PM   #2
bobs86silv
bobs86silv's Avatar
Re: Need help identifying truck
That looks like the same color as my 86 silverado.. With the four headlights I am thinking it might be a sierra grande... Same as silverado really, probably 86 or 87.. Im sure someone will be able to correct/verify that for sure!!
86 Silverado SWB 350/350/3.08 9.7-1 Forged pistons Eagle Rods Eagle Crank Zero Deck Balanced Blueprinted 180cc DART Heads Roller Rockers RPM Intake Demon Carb Flowtech Headers 400HP/400TQ
bobs86silv is offline   Reply With Quote
Old 01-14-2008, 02:15 PM   #3
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Yeah im going with 86 gmc
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 01-14-2008, 02:39 PM   #4
89 crew
Isn't that a gas cap sticking out on the passenger side? If so then the bed is 73-77 or 78.
89 crew is offline   Reply With Quote
Old 01-14-2008, 02:41 PM   #5
ChaseDale3and8
ChaseDale3and8's Avatar
Could be an 85-87 GMC judging by the grill providing that it hasn't been changed at some point. Looks like the front fenders have either been changed to 89-91 or the emblem holes have been filled.
Looks like a mix and match of parts by the looks of it. The bed is off of a 1978 or earlier truck. You can tell by the round gas cap. 79 and later had a fuel access door. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 01-14-2008, 02:49 PM   #6
blink32
blink32's Avatar
Going just off the body I'd say its a 73-78 with an 81+ front clip.
The bed, cab and doors are faded to match where as that front fender is much brighter indicating a newer replacement. The front fender is definitely an 81+ because of the orientation of the turn signal and the grill with quad headlights. The bed is 73-78 because of the previously noted gas filler. In 78-79 GM moved to fuel doors instead of gas caps on the outside. Although I have a factory 76 with fuel doors. Of course a quick check of the VIN would clarify everything.
blink32 is offline   Reply With Quote
Old 01-14-2008, 02:51 PM   #7
ChaseDale3and8
A couple of other things that would help narrow down the actual year would be the axles and transfer case. If it has a 10 bolt rear, 10 bolt corporate front, and an aluminum 208 transfer case, it's likely to be an 81 and up. 12 bolt rear, Dana 44 front, and either a 205 or 203 cast iron transfer case would indicate 77 or earlier. It could possibly be an earlier truck that has had a cab swap done. The drivetrain would give you a better idea of the actual year. ...Joe
Old 01-14-2008, 03:04 PM   #8
ChaseDale3and8
As indicated above, the real year would be the VIN #. The VIN number on the frame will give the true year of the chassis, no matter what year cab has been swapped on. ...Joe
Old 01-14-2008, 03:33 PM   #9
ErichK
Can anyone tell me exactly where to find the VIN # on the frame?
Old 01-14-2008, 04:33 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The VIN is on the dash, driverside. On the frame for older models, driverside near the #3 and #5 cylinders.
gchemist is offline   Reply With Quote
Old 01-14-2008, 04:36 PM   #11
ChaseDale3and8
It should be stamped into the left side framerail under the cab behind the front cab mount if memory serves me correct. You should be able to crawl underneath and find it rather easily. ...Joe
Old 01-14-2008, 07:18 PM   #12
Pyrotechnic
Pyrotechnic's Avatar
I almost wanna say it's a 81+ truck with an older bed on it. I figure the original bed may have gotten damaged early on and an older used bed was available for cheap, so they painted it to match the existing cab and fenders. I say this because the bed and cab are faded the same and the paint loots quite old. I think the new looking fender might be something recent, from a fender bender and the really couldn't factor that much fade in and didn't want to repaint the whole truck so they just painted it the same colors.
Pyrotechnic is offline   Reply With Quote
Old 01-15-2008, 09:50 AM   #13
ErichK
I've looked all over the frame, in the door jam, and on the firewall, but the only VIN # I can find is the one in the windshield, but it's slightly rusted, so I can only partially read it.
Could anyone take a picture of the location of the VIN # on the frame?
Old 01-15-2008, 03:41 PM   #14
gchemist
gchemist's Avatar
Can you read at least the first few digits?
http://www.lmctruck.com/icatalog/csb/full.asp?page=9
Old 01-15-2008, 04:10 PM   #15
manimal
manimal's Avatar
I have a '75 K10 and the vin is on the pass side frame rail next to the fuel pump.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 01-15-2008, 07:16 PM   #16
ErichK
I found the VIN number and looked it up. Turns out it's a 1986 K10 Pickup truck. Cheers to everyone who helped me out.
