Old 01-14-2008, 02:55 PM   #1
cory321
Problem Child
cory321's Avatar
Rearching Springs
The rear passenger side spring on the gmc is sagging.If i were to have it rearched would it affect the ride quality any.Or would it be better to just replace both rear springs with new ones.
Cory
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 01-14-2008, 03:11 PM   #2
Sweet72
Sweet72's Avatar
Re: Rearching Springs
I'm not familiar with the term "rearched". Must be a leaf spring thing...
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-14-2008, 03:12 PM   #3
cory321
Problem Child
cory321's Avatar
Yep.Its leaf springs
I Survived Norwood
Old 01-14-2008, 03:45 PM   #4
cdowns
cdowns's Avatar
it wouldnt be wise to just do 1 spring weather rearching or replacing you need to do both replacement is a better choice and i doubt theres a real price advantage to rearching them
Old 01-14-2008, 06:01 PM   #5
Huskerboy2
I had my rear springs on my Blazer re-arched. It leveled the truck out real nice and the ride is the same as ever. That was 7 years ago.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 01-16-2008, 11:22 AM   #6
chris71
chris71's Avatar
i would just get 2 new springs, or at least two used ones from a yard, off of a truck that you know is not sagging. there must be some reason for it to sag in the first place, if you rearch it it may last a while but in 10 years it mat sag right back. its a gamble. there may be a defect in the spring somewhere. good luck
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 01-16-2008, 01:24 PM   #7
cory321
Problem Child
cory321's Avatar
Thanks for the responses.
I will most likely get 2 new springs
I Survived Norwood
