01-15-2008, 09:45 AM | #1 |
Steering bones connected to the leg bone leg bones connected to the rack bone. Pics
Well guys I was not sure this could be done but it works. After about 15 hours of planning, thinking through problems and designing mounting plates and bracing the 18" Ididit tilt column is in and is connected to the power steering rack. As it seems with modifications there is always a relationship to other working pieces that have to be considered as you build something. My brain is sizzled so I think I will go have a beer. Thanks for keeping up with my build. Have a great day!
01-15-2008, 09:53 AM | #2 |
Re: Steering bones connected to the leg bone leg bones connected to the rack bone. Pi
Rest of pictures
01-15-2008, 10:04 AM | #3 |
That looks great! What was your reason for comming out so low with the column? Just for looks of a nice clean fire wall or was your front suspension and motor just too tight to make it work other wise? Oh ya we want more pic's, front suspension, engine, body .....
Kevin LFD Inc. |
01-15-2008, 04:04 PM | #4 |
In answer to your question. My first object was to have nothing on or through the firewall. Well the shaft does go through the firewall but is in a not so noticible place. The truck has a Scotts Hot Rods IFS front suspension with a power rack and pinion. Most all 67-72 trucks at shows I have ever seen always have the brake booster and steering column in the stock location. I set out to build one of the nicest trucks and this was just part of the overall plan. Thanks for asking.
01-15-2008, 05:02 PM | #5 |
Do you have any pics of the booster mounted under the cab? Does it hang below the frame at all?
Thanks and it is good to see somthing well thought out. Kevin LFD Inc. |
01-16-2008, 11:11 AM | #6 |
Looking good, I was thinking about running the same column in mine.
06-09-2008, 01:25 AM | #7 |
clever title here
do you know what the original application was for the rack and pinion was? i am looking to convert mine.
06-09-2008, 11:31 AM | #8 |
The rack and pinion is from a Mustang II. This lets you have Mustang II spindles and a choice of many wheel types for the truck.
