Old 01-15-2008, 03:32 PM   #1
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
brake question
anyone know the bore size for front calipers and rear wheel cylinder on a 12 bolt?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-15-2008, 05:29 PM   #2
89 crew
Re: brake question
The calipers are pretty much standard but I don't remember the size. The wheel cylinders are different depending on the size of the shoes and there are several as I recall.
89 crew is offline   Reply With Quote
Old 01-15-2008, 05:40 PM   #3
smashingchuck
Re: brake question
still have to know, need to spec out a new master cylinder.... none of these truck came with out power brakes did they?
78 Build Thread
4Runner Build
Old 01-16-2008, 01:08 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: brake question
Yes you could get manual brakes on any of the base models. Power was an option.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-16-2008, 02:02 PM   #5
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Re: brake question
Manual brakes on disks? Man, that's be hell on wheels trying to get that pulled to a stop....
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 01-16-2008, 02:52 PM   #6
OJOE
Crew Cut
OJOE's Avatar
Re: brake question
i have a 85 c10 in my junk trucks with manual disk. i guess just stand up on the brake. on same truck, no p/s or a/c with a 3 on the tree
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-17-2008, 06:46 AM   #7
smashingchuck
Re: brake question
yeah... but the power booster doesn't exactly fit very well under the dash
78 Build Thread
4Runner Build
Old 01-17-2008, 11:13 AM   #8
Captkaos
Captkaos's Avatar
Re: brake question
I ran manual brakes on my 73 for years and it had a built 454, 4 speed and a loose nut behind the steering wheel. Never was a problem stopping it. I did convert to power steering though as turning it was murder...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-17-2008, 02:53 PM   #9
OJOE
Crew Cut
OJOE's Avatar
Re: brake question
i have a brake booster turned cross ways under the very small dash of my model "A" hot rod, works real good with the 4 wheel disk brakes.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 01-17-2008, 07:35 PM   #10
smashingchuck
Re: brake question
so.... maybe I should just get a master cylinder for one with manual brakes....
are they different or do they have the same 1-1/8" bore?
technically the power booster would fit, I'm just having a hard time getting the linkage to work.
78 Build Thread
4Runner Build
Old 01-18-2008, 12:44 AM   #11
Captkaos
Captkaos's Avatar
Re: brake question
Don't quote me on this, but I think the manual is slightly larger... I honestly don't remember and the truck is about 40 miles away.
On the linkage, make a Z-bar mounted vertically. Then the when the pedal pushes the bar it will pivot and the other tab will apply the brakes. Just make sure it is the same amount of travel...
They make a kit for this ya know, but I am guess you are making your own...
Found the manufacturers:
http://ecihotrodbrakes.com/hanging_p...ssemblies.html
http://www.kugelkomponents.com/produ...akesystem.html
If anything, you can use it for examples...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-18-2008, 01:12 AM   #12
smashingchuck
Re: brake question
I'm making my own, it's pretty much done. the kits really wont work I'm building it on to the the bracket that holds the brake and clutch pedal.
78 Build Thread
4Runner Build
Old 01-19-2008, 03:37 AM   #13
smashingchuck
Re: brake question
hey chris, I got a manual brake master cylinder like you had (an 85). It actually has a stepped bore in it. 1" for the front and about 1-7/16" for the rear. My question has know turned to:
Proportioning valves
are they all the same? It seems like with the stepped cylinders in the master cylinder you wouldn't even need one... but I'm not sure. Any insight? Did your parts truck even have one?
*edit*
while I'm asking you questions... one thing about those windows we've been discussing for a year now. To make the templates, I would need to have all the stuff that comes with the kit except the windows, to make sure if fit the opening correctly. Do you think it would be possible to get the kit minus the glass so I can make the template?
78 Build Thread
4Runner Build
Old 01-23-2008, 11:07 AM   #14
Captkaos
Captkaos's Avatar
Re: brake question
Prop valves should be the same for the JB1 brakes, boosted or not from all I can tell...
I can't get you the kit minus the glass.... as for the template, he would just need the pattern for the window opening, the rest of the door would be the same (unless you channelled the truck)
Chris Lucas
1973 Chevy C-10
Captkaos Customs
