10-17-2002, 02:37 PM | #1 |
Livin' it up.
Line lock/E-brake alternative
Ok fellas i'm looking at converting the rear of my truck (with the HO72 axle) to disc and dont really want nor think it worth it for me to get the e-brake calipers. Anyone out there make or heard of something that locks up the brakes like a line lock but that you could use like overnight or for some period of time. kinda like a manual solenoid or something i guess. Any thoughts or suggestions? Thanks
Greg
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
10-17-2002, 04:27 PM | #2 |
i've seen hydrolic ones..but there in line so if you put it inside your cab you would have to run a brake line inside..there just a push - pull knob
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
10-17-2002, 05:15 PM | #3 |
Progress = 0%
Well, a line lock won't do you any good if your brake system fails which is the reason for an e-brake in the first place. The e-brake needs to be of a mechanical nature, so it'll activate the brake shoes without the use of the brake lines/master cylinder.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
10-17-2002, 11:54 PM | #4 |
Livin' it up.
hey mooneyes do you possibly have a link or any ideas for places to go. I'd be alright with putting one under the hood or something and then when i park just go set it, i guess i could run one into the cab, it'd be fun to plumb but worth it i suppose.
Slammed67: i realize that point but i've yet to see an e brake on any of my vehicles that did any good, i can still roll the dang things no matter what i tried adjusting them. Keep the input coming folks
10-18-2002, 03:41 AM | #5 |
English Chevy Owner
What about some kind of transmission brake like they have on old Land-rovers. It has a drum on the driveshaft and the back of the gearbox. Not sure exactly how it works or if something could be adapted to suit? You would then be able to use your original handle/pedal setup.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
10-18-2002, 09:55 AM | #6 |
Blackbird's rear disc kit looks pretty slick to me. I know adding the e brake adds $140 to price, but by the time you fab up some kinda line lok you'll probably spend that anyway and then not have an "emergency" brake. If you don't have an e-brake that'll lock up the rear, you need to repair/ adjust it. They're capable of doing that easy. (BTW... the pot IS calling the kettle black, here. My e-brake isn't working currently either...
Dutch 1972 Super Cheyenne K20 1976 MGB 1950 Harley FL 1997 Arctic Cat ZR580 "Maybe if I had a couple less hobbies, I'd have time to enjoy one!" |
10-18-2002, 04:28 PM | #7 |
Jc whitney's got them and i think some tractor or industrial stores may have them also
10-18-2002, 05:42 PM | #8 |
member #16
One thing to consider with a line lock,if the brakes are hot when you set it they will release as they cool off. Saw that happen once resulted in crunched front fender.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
10-18-2002, 07:24 PM | #9 |
"Line Locs" are illegal in some states if used as an Emergency brake. Not sure if your state has inspections, but this may be something to think about.
10-18-2002, 08:54 PM | #10 |
It was actually an option to have an emergency brake set up on the back of the tranny... like a brake drum that you just expanded the shoes to lock things up.I saw one on a 72 chev with a six cylinder 4 spd.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
10-20-2002, 10:36 AM | #11 |
English Chevy Owner
The great thing about a transmission brake if you have a 4x4 is that with the transmmission in fourwheel drive it locks all four wheels, not just the rears. Great as a parking brake not so ggod if you do need to use it in an emergency as you have one set of shoes in a smaller drum.
10-20-2002, 11:19 AM | #12 |
Seņor Member
I've seen one on Ford rearends that is a single disc on the front of the third member. I'm looking for a link now...
Kenneth
10-21-2002, 02:32 PM | #13 |
TOTY 2006
Do a search online for driveshaft mounted ebrake.
Where your driveshaft meets the rearend, you can mount a rotor and caliper, and then you can use your regular ebrake cable to enable it. I have seen a couple that were made for Ford 9inch rear ends. |
10-21-2002, 07:25 PM | #14 |
Livin' it up.
Great ideas all thanks much, i definately will hafta make some sorta e-brake setup for this thing if/when i convert it.
11-05-2002, 08:11 PM | #15 |
How about some thing like this.
quote]
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
11-05-2002, 08:28 PM | #16 |
thats basically what JCWitney has but its a push pull instead of a lever
11-12-2002, 12:56 PM | #17 |
Shouldn't the trans-mounted e-brake work better even if it is smaller? When applied, it's force would be multiplied through the gearing of the rear the same way HP would be, just decelerating instead of accelerating. Though maybe if you have an open diff, you'd only have one wheel doing the stopping too...hmmm......
Greg
No such thing as a stupid question, right? |
11-12-2002, 01:43 PM | #18 |
Getting cabin fever?!?!?!
pick up the newest 4 wheel and off road. they've got an article on installing a disc e brake on the drive shaft. looked pretty slick. you may need a new drive shaft which would kinda kill the cheap part of the plan but it would look killer!!
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
