Old 01-15-2008, 06:19 PM   #1
75gmc454
75gmc454's Avatar
77 1/2 ton 454 suburban
I found a 77 suburban in the junkyard with a 454. It is complete with the rad, shroud, a/c, etc. So I want to buy the suburban and take the drivetrain out and put it in a lwb chevy truck that is about the same mid seventies model I can use for towing. Would the driveshaft be the only problem with that swap? What is the difference between the wheelbase on the suburban and the truck?
I already have a 73 gmc 454 and it has a two piece driveshaft even though it is a short wheel base. As for the engine in the burb, I dont have a truck to put it in yet. I want a lwb and would like to get by with a one piece driveshaft. Any suggestions?
75gmc454 is offline   Reply With Quote
Old 01-16-2008, 01:03 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: 77 1/2 ton 454 suburban
Buy the sub and yank the drivetrain. When you get the LWB, stuff the drivetrain into it. Measure for a solid driveshaft and send the measurements to a shop and get one made. Pretty simple.
Or, take the one piece shaft from the sub and send it to a driveshaft shop to get lengthend to the size needed. At least this way would be cheaper because you are providing them with the yokes rather than starting from scratch.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-23-2008, 08:03 AM   #3
streetstar
streetstar's Avatar
Some of the members have some pretty stout trucks (650 hp, stuff like that) that they use on the 'strip with two-piecers, if its strength that your worried about.
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 01-23-2008, 02:42 PM   #4
Mkcustums
Mkcustums's Avatar
1973 to 1991 Suburban 129.5 in (3289 mm)
1973 to 1987 Truck 117.5 in (2985 mm)
----- -- ---------- 131.5 in (3340 mm)
----- -- ---------- 164.5 in (4178 mm)
Mkcustums is offline   Reply With Quote
Old 02-01-2008, 04:22 AM   #5
TLoz
75gmc454,
After you gut the salvage burb, what are you going to do with the frame? I'm looking for some of the body mount brackets and a rear 18" on one side.
Thanks, Tom
TLoz is offline   Reply With Quote
