Old 01-16-2008, 06:41 AM   #1
Richard Dobson
Pitman Arm to Steering Linkage Torque?
What is the torque for the nut that holds the pitman arm to the relay rod (not the steering box) with the tapered shaft? It doesn't have a cotter pin so it needs to be torqued. Thanks
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 01-16-2008, 10:13 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Pitman Arm to Steering Linkage Torque?
You might see if it is here:
http://www.73-87.com/7387garage/chas...n/frontend.htm
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-17-2008, 02:29 AM   #3
Richard Dobson
Thanks Slonaker guys like you are what makes this forum great. It says to torque the nut to 41 ft./lbs. Have a great day.
Richard Dobson
Old 01-17-2008, 02:39 AM   #4
Richard Dobson
Oh, I didn't notice it says to put in new cotter pins. My 84 doesn't have a cotter pin, the tapered shaft on my pitman arm doesn't have a hole for one. Do you think this torque setting still applies to my truck?
Richard Dobson
Old 01-17-2008, 06:27 AM   #5
Slonaker
Slonaker's Avatar
I'm not familiar with the term "relay rod." Does it have any other names, or do you have a pic? I can go look at mine, and see if it has a cotter pin.
I'm no expert. When I rebuilt mine, I just reassembled everything the way it came apart, and torqued it according to the specs on that page.
Have you looked at the manual for your year of truck on autozone.com? They have some of that kind of info for free. I can also look it up in my '86 shop manual if I can figure out which parts you are asking about.
Slonaker
EDIT: I think this has your answer. It is hard to read, but it says something like "torque it with a regular nut to 40 ft lbs to seat everything, then remove the nut and replace it with a locking one."
http://www.slonaker.net/8577R08_Steering_Linkage.pdf
Let me know when you have the doc, so I can pull it down from my site.
Stock '01 Silverado
Old 01-17-2008, 02:03 PM   #6
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
As per my idiot book:
60 lbs for the Pitman arm to relay rod nut.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 01-17-2008, 02:31 PM   #7
Richard Dobson
My pitman arm has a tapered shaft on the end where the relay rod attaches. I don't know if the previous owner modified something or not but there is no cotter pin hole in the tapered shaft. It also does not have a castle nut which needs a cotter pin.The nut that goes on mine is a lock nut which has the depressions on the side of the hex flats which I assumed were there because the nut was punched to deform the threads. Since there is not cotter hole pin in the shaft the nut needs to be torqued, which I assumed is the way all 84 steering boxes are made. Am I making any sense.
Richard Dobson
Old 01-17-2008, 03:22 PM   #8
PhilaTruck
PhilaTruck's Avatar
Yes, but you're beyond my experience. Is it possible to post a picture, it might help? BTW, that was a good description-
Subscribe here!
Old 01-17-2008, 03:28 PM   #9
Slonaker
Slonaker's Avatar
Look at page 2 figure 2 on my PDF. I think it is saying to first use a regular nut torqued to XX ft lbs to seat it, remove it, then torque the locking nut to actually hold it in place. That's the way I read it, at least...
Slonaker
EDIT: I assume this is because you can't get an accurate torque reading from the locking nut.
Stock '01 Silverado
