Old 01-16-2008, 08:24 AM   #1
blazntn
Disc and Drop Spindles
Ok guys I have installed a C4 rearend in my 69 C-10. My question is about the front. I want to run the 5x4.75 bolt pattern. Currently I have six lug disc in the front with drop spindles. Just curious if there is a 5 lug rotor that will be a direct fit on my spindles. Then I can have the new bolt pattern drilled out.
thanks
Brad W
www.gaugemagazine.com
blazntn is offline   Reply With Quote
Old 01-17-2008, 08:47 AM   #2
blazntn
Re: Disc and Drop Spindles
BUMP!
Does anyone have any suggestions???
Old 01-17-2008, 11:06 AM   #3
SCOTI
SCOTI's Avatar
6-lug disc kits are typically based on one of two options: 71-87 disc spindles/rotors or 88-98 lt. duty (3/4 ton) spindles/rotors.
We would need to know which kit you have to be of any help. Meanwhile..... 'reverse' search any of your P/N's you know & see what they vehicle originated from.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2008, 10:15 PM   #4
blazntn
well the previous owner installed everything. I am not sure who made them. Didnt even see any markings. Is there any other way to tell?
