Old 01-16-2008, 10:00 AM   #1
HotRodYJ
HotRodYJ's Avatar
Bag clearance when cutting lower cups?
I read alot of you guys are using top plates and cutting the lower bag cups down to an inch or so. Looks to me like cutting the cup down so much, the bag will rub on the LCA when aired out, at least mine would. Anybody got any pics of bag to arm contact when using such a low cup? Is touching when aired out not really a bad thing as long as there is no contact when aired up and driving? I'm running 77 front susupension on my 66.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 01-16-2008, 04:23 PM   #2
bedsled71
bedsled71's Avatar
Re: Bag clearance when cutting lower cups?
mine touches when aired out. hasnt caused any problems after 4 years
bedsled71 is offline   Reply With Quote
Old 01-16-2008, 04:27 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
I stayed at 1.5" w/ 73-87 LCAs. 1" cups had me rubbing at ride height at the inside edge and near the shock mount. Rubbing aired-out should cause you no problems...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-16-2008, 09:09 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
1.5" total height cups on my truck (I have to specify what I'm referring to with these yahoos )
Frizzle Fry is offline   Reply With Quote
Old 01-17-2008, 01:15 AM   #5
HotRodYJ
HotRodYJ's Avatar
Thanks guys for the info. Anybody got pics so I can see what it looks like? Thanks!
Old 01-17-2008, 05:44 AM   #6
Tony@AirRideTech
Junior Member
As long as it rolls over on a smooth surface you will be fine. If there is an edge or a lip.... fix it.
Tony@AirRideTech is offline   Reply With Quote
Old 01-17-2008, 11:07 AM   #7
Frizzle Fry
Old 01-17-2008, 03:11 PM   #8
HotRodYJ
HotRodYJ's Avatar
Thanks Mike! Pics may me feel better about it
