?????? about dash
Hay guys is there some sort of cover that goes under the dash ?where the steering colum goes. not the one that the rubber stop is on for the brake pedal some sort of panel that covers that up . a pic would be nice if any body has any info thanks
nickle and dime |
its all about the +6 inches
Re: ?????? about dash
nope, but you can custom make it and share the photos when you're done!
oh man it looks like something is missing thanks for the info
nickle and dime |
wait... after re-reading this...
you just talking about where the column goes under the dash... where the two meet up? If so, then yes, a rubber piece and a metal piece go there. I was thinking a cover for the whole underside of the dash board... from door to door. |
#5 | |
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#6 | |
nickle and dime |
crappy cell phone photo of the longhorn;
If you buy an assembly manual it will show this very good. It will also answer a lot of other Questions. Also LMC Catalog is pretty good. Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 01-16-2008 at 07:18 PM. |
Thanks so there is a cover there
nickle and dime |
Looks like this...
nickle and dime |
I am a Referee of life.
Any board vendor will have the rubber.should be easy to find the metal plate from any wrecking yard or on the parts board.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#13 |
You can get it through LMC. I believe the picture Corn sent is from the LMC catalog.
#14 |
thanks guys
nickle and dime |
