Old 10-17-2002, 04:54 PM   #1
nosto
Flamin' Bass
nosto's Avatar
10.5cfm for $250 ??
Was browsing through the local Sears. Stopped by the air compressors and saw their <DeVilbiss, vertical, black, single stage, 60gal, 135psi> $499 model #18417 on clearance for
$249.99.
Of course they don't have any more in stock, can't order any, and the nearest 5 Sears stores don't have any either.
But, if you're looking for a compressor, this seems to be a decent size for the price.
That is, if you can find a store that still has one.
Cheers,
Rick/nosto/
Still lookin' for more cfm
nosto is offline   Reply With Quote
Old 10-17-2002, 05:56 PM   #2
crazy4chevs
crazy4chevs's Avatar
I have a 7 hp 60 gallon single stage compressor 135 psi.
(wish I would've got a two stage )
You should check to see if its a two stage or not. Two stages are far superior- less wait time, with little more investment. Remember its a tool you should buy one for life not to get you by and replace in a few years.
I should have read your post slower, I see it's a single stage. Not a bad price though!
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 10-17-2002, 09:40 PM   #3
crazy longhorn
Fabricate till you "puke"
I have a 5 hp/ 2 stage/80 gal tank, 18 cfm @ 175 psi, it wasnt cheap at $1200.......but i have been workin the nuts off it for 15 yrs! alot of the "high end"air tools like a die grinder take about 12 cfm to run , & sand blasting really eats the air! I have a pressurized blaster canister that i use for small parts, & have a little wait time while blasting. watch out for the 'oiless " compressors(sealed pump), that you cant add or change oil in.....they are a throw away item & a lot of the cheaper units are set up this way. Take a look at the air tools you plan to use, & get an idea what you need for compressor sizing, then be prepaired to spend a little extra cash.......in the long run you will be happier. good luck......crazy longhorn
crazy longhorn is offline   Reply With Quote
