Old 01-16-2008, 10:40 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
tie rod reinstallation problem
today im putting back together my front suspention and im basically done except for my outter tie rods. i tried to put it back on the spindle, but the nut gets to tight and im not even close to the cotter pin hole. does this have to be pressed in? what do yall think?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 01-16-2008, 10:46 AM   #2
70GMCer
70GMCer's Avatar
Re: tie rod reinstallation problem
What changes did you make on the suspension? Did you replace the spindle? That may call for a different tie rod end.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-16-2008, 11:03 AM   #3
cdowns
cdowns's Avatar
are you sure you're putting them in the right way to match the taper? also different spindles have different taper tierods
Old 01-16-2008, 11:39 AM   #4
crm318
crm318's Avatar
it was the same spindle and the same tie rod end. i just had to replace the bushings and ball joints.
1972 Cheyenne
Old 01-16-2008, 01:59 PM   #5
crm318
crm318's Avatar
i am now trying to put the castle nut back on the tie rod and the threaded part of the tie rod is spinning and preventing me from putting the nut back on. is it broken?
1972 Cheyenne
Old 01-16-2008, 02:02 PM   #6
CharlieBrown
CharlieBrown's Avatar
you need some air power
or..use a jack..under the tie rod end..apply some pressure to seat the taper..then you should be able to tighten it up
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 01-16-2008, 02:33 PM   #7
JCA1972
JCA1972's Avatar
the tie rod bolt should tighten up against the spindle as you are tightning the nut and it shouldn't spin, did you remove the tie rods completly, maybe you got them on backward, I don't know, if it came out it should fit just fine.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 01-17-2008, 07:37 AM   #8
crm318
crm318's Avatar
the tie rods were never removed, only the spindle. all the parts are the same ones as before. i have even tried heating the nut to see if it would go on. the nut only goes on so far and then the tie rod bolt starts spinning.
1972 Cheyenne
Old 01-17-2008, 07:54 AM   #9
jorgensensc
jorgensensc's Avatar
Sounds like the tie rod is broken. I suggest getting a new one.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-17-2008, 11:32 AM   #10
crazy longhorn
Fabricate till you "puke"
Remove the boot, & stick the rod end back in the spindle...... does it fit tight when you push it all in? Check it for wiggle in the spindle. IIRC, I caught a post on a arm bushings, & it sounded like you have the rubber bushed (73 up) arms on the truck. If you are running 73 up spindles, the last guy in could have tryed to bolt the 72 tierod ends in, & they wont pull up as far 'cause of the diff in taper on the rod end. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-17-2008, 04:05 PM   #11
crm318
crm318's Avatar
go got it on. i ended up heating the castle nut hot enough and it fit like a glove. thanks for all the help guys.
1972 Cheyenne
