Old 01-16-2008, 11:34 AM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Concealed Fuel Neck in my Stepside
I am getting ready to fabricate a concealed fuel neck in the D/S rear marker light. There have been a few threads buy members who have done this, so I'm gonna try it. My biggest issue was down sizing the end of an S-10 neck (2 inches) to the fill neck on the blazer poly tank (1-1/4 inch).
Was gonna use exhaust pipe but could not find 1-1/4 inch. 3/4 inch buy the way was an big jump. 1-1/4 inch copper tube was too soft.
Here's what I came up with. Our local plumbing supply house (not H/D or Lowes) suggested the following reducers: Copper 2 inch to 1-1/2 inch reducer then a Copper 1-1/2 inch to 1-1/4 inch reducer. The 2 reducers measure 4 inches long. Everything slips in real nice and I'm gonna have it tig welded for clean connection. Here's some early stage pics:
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 08-06-2008, 09:15 AM   #2
jorgensensc
jorgensensc's Avatar
Re: Concealed Fuel Neck in my Stepside
That is exactly how I did it. Only difference i I used exhaust reducers from the auto parts store. I don't have any idea how copper would react with gas. I'm sure it would be fine, but I might check first. Plus your welding two disimilar metals, and I don't know how easy that would be either.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 08-06-2008, 09:33 AM   #3
mr48chev
mr48chev's Avatar
That was my thought, I don't believe you can weld copper at least most folks can't.
I would go with the exhaust fittings as jorgensensc said he did. that is pretty much the normal thing to do. A Good muffler shop can also swedge the fittings up for you exactly how you want them.
mr48chev is online now   Reply With Quote
Old 08-06-2008, 11:35 AM   #4
myoldchevytruck
Shawn
Hey guys,
This has already been finished and I have changed plans and have gone back to the stock tank since this was posted back in January. We Silver Soldered everything together. Tig Welding would have been another way. Thanks for the input.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
