01-16-2008, 12:03 PM | #1 |
Life, Be In It.....
Cardboard Dash Tube?
Its the tube that goes inside the dash bezel for the turn signal and high beam lights. I remember seeing them for sale on one of the parts sights but I can't remember which one. Does anyone know?
THANKS FOR THE HELP......HAHAHAHA. I FOUND SOME. WWW.EARLYCLASSIC.COM HAD THEM.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 01-16-2008 at 12:54 PM. |
01-16-2008, 02:30 PM | #2 |
Active Member
Re: Cardboard Dash Tube?
A long time ago I made my own out of stiff card stock. I used the old one as a model and cut them the same diameter and length. Worked pretty good.
01-16-2008, 02:38 PM | #3 |
67-72 Addict!
You can use 3/4" pipe that will last forever and looks great because it's white on the inside!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-16-2008, 02:41 PM | #4 |
Jim -70c10;You can use 3/4" pipe that will last forever and looks great because it's white on the inside. thanks 463
thats a good idea Last edited by 463; 01-16-2008 at 02:42 PM. |
01-16-2008, 03:03 PM | #5 | |||
Union Electrician
I have a blue million of these little tubes, plastic color tops and gaskets for the high beams and turn signals if anyone needs anymore.
I like to make the turn signals red and the high beam green just S&G.....Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
