Old 01-16-2008, 02:50 PM   #1
52 rules
52 chevy 4 link
i recently installed a 4 link rear end on my 52 chevy with a 85 firebird rearend with disc brakes and was wondering if the track bar takes the place of the pan hard rod or should it have both.
52 rules is offline   Reply With Quote
Old 01-16-2008, 06:29 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: 52 chevy 4 link
Post some pics so we can see what you're referring to. There only needs to be one link that locates the axle laterally. A trac-bar does the same thing as the pan-hard bar.... are you referring to the torque-arm? (the link that goes from the diff. to the trans mount?)
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-17-2008, 01:48 PM   #3
52 rules
Re: 52 chevy 4 link
i order a the 4-link kit from totalcostinvovledfor a 52 chevy with an 85 firebird rearend. When i asked fro the pan-hard rod kit to go with it the kit they had was only for the ford 9inch rearend so i would have to find one somewhere else or make one.When the kit came it had an extra bar, so when i started looking through the magazines i seen this complete 4 link kit with a trac bar going from the rear of one link to the front of the other link on the opposite side. A frined told me i needed a pan hard rod also. i figured the pan-hard bar would not work properly with the trac bar. Now i am wondering which of the 2 set ups would be strongest bescause is i can get a way with just using the trac bar it would be better because it would leave me room for my exhaust and spare tire.(http://www.totalcostinvolved.com/pro...cfm?prodID=833) this is the trac bar)
(http://www.totalcostinvolved.com/pro...cfm?ProdID=538) this is the pan hard rod)
Old 01-17-2008, 04:20 PM   #4
7T7
Regular guy
7T7's Avatar
Re: 52 chevy 4 link
What you have there will work fine, no panhard bar is needed.
Air Ride Technologies sells a diagonal set up similar to the TCI set up you have.
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
