Old 01-17-2008, 12:02 AM   #1
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
73-87 suburban bolt in 4 links????
looking 4 a bolt on 4 link (preferably cantilever) for a 73-87 suburban does anyone know any companies that make one?
GMBowtie79 is offline   Reply With Quote
Old 01-17-2008, 05:54 AM   #2
Tony@AirRideTech
Junior Member
Re: 73-87 suburban bolt in 4links????
We have not tried to stick ours on a burban yet.... I have had some guys bolt them onto blazers with little trouble but I am unsure about the burb.....
Tony@AirRideTech is offline   Reply With Quote
Old 01-17-2008, 07:02 AM   #3
GMBowtie79
GMBowtie79's Avatar
Tony, I talked to clint @ KP and he told me that with the body mount by the front spring mount was an issue from what I've seen of your product it will have the same problem. Thanks
Old 01-17-2008, 07:26 AM   #4
Kontrol Phreaks
Kontrol Phreaks's Avatar
Yeah there's a body mount on the outside of the frame in the area where the link bars would go. If you can go ahead and modify the body mounts, then you would be able to run our kit.
One of our local dealers is currently building a 73-89 Suburban with our suspension components. If you want more information before purchasing a kit, I can contact them and have them verify some specs for me.
Let me know.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 01-17-2008, 07:29 AM   #5
Kontrol Phreaks
Don't ever stand behind Tony once he's has Mexican food . <--- Unless you're wearing fart retardant pants .. hahahaha.
- Clint -
Old 01-17-2008, 07:39 AM   #6
GMBowtie79
GMBowtie79's Avatar
Thanks Clint, thats what you told me when I talked to you before. right now still working on the tie rod issue.
Old 01-17-2008, 07:48 AM   #7
Tony@AirRideTech
Junior Member
Dude.... you ought to know by now... Being a native born Texan and growing up in new Mexico.... Mexican food keeps me regular. Now give me some fried chicken or fried anything..... you better be backin up
Old 01-17-2008, 08:19 AM   #8
Kontrol Phreaks
Next time we roll to Pleasanton then we'll skip the Mexican place downtown on the strip and take you to KFC instead ..
- Clint -
Old 01-17-2008, 08:24 AM   #9
grnddwn
belly dragger
grnddwn's Avatar
Clint have you guys put one on a 1999 2 dr tahoe?
Stay away from KFC you get haunted by the poultrygiest
SAVE THE PLANET DRIVE AN OLD TRUCK
grnddwn is offline   Reply With Quote
Old 01-18-2008, 02:35 AM   #10
Mkcustums
Mkcustums's Avatar
Let me know.
I would like some info on that if you don't mind. (pictures?)
Thanks!
Mkcustums is offline   Reply With Quote
Old 01-18-2008, 02:54 AM   #11
Tony@AirRideTech
Junior Member
Im game ...... and we will go out and pick you up some big girl!
Old 01-18-2008, 02:56 AM   #12
SCOTI
SCOTI's Avatar
KFC? Are you freakin' kiddin? Tony loves the 'white meat' from Popeye's!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-18-2008, 02:58 AM   #13
Tony@AirRideTech
Junior Member
heall yeah!
Old 01-19-2008, 03:44 AM   #14
Kontrol Phreaks
[QUOTE=grnddwn;2532424]Clint have you guys put one on a 1999 2 dr tahoe?QUOTE]
If that's still the old body style like the 88-98 trucks, then yes we have. You can run our weld-on parallel 4 link, cantilever conversion kit, and an 88-98 cantilever kit out back. The rear cantilever will need to be welded to the frame rails as the bolt patterns are different and don't line up. Our local installed did on with the Tahoe on 22's and it looked awesome. He raised the tank up slightly, but did not modify the rear floor section. If you were to raise the tank up higher, and the floor section above it, then you could get the truck down that extra inch to safely lay frame, and not smash on the gas tank.
- Clint -
Old 01-19-2008, 03:47 AM   #15
Kontrol Phreaks
Hummmmm ????? When I was over at his place for Thanksgiving, all he could talk about was getting his hands on some of that dark meat.
- Clint -
Old 01-20-2008, 12:14 AM   #16
Tony@AirRideTech
Junior Member
Re: 73-87 suburban bolt in 4 links????
as long as the dark meat resembles Penelope Cruz, Selma Hyack or Hali Berry.... I am game for sure!
Old 02-16-2008, 09:16 AM   #17
jbjburbs
jbjburbs's Avatar
bolt on 4 link for 92-99 suburbans??
been looking into it, i think i could build rather easily, but i'm feeling lazy. Bolt whole patterns don't scare me near as much as welding all kinds of mount brackets to my frame and axel... any suggestions?
i was leaning towards a kit simular to AirBar, but since the frames all different in those trucks.. ask airride they will tell you..
John J
Bodied 1994 Suburban on custom frame -
http://67-72chevytrucks.com/vboard/s...d.php?t=672297
Dad's 1948 Suburban -
http://67-72chevytrucks.com/vboard/s...d.php?t=563150
Bagged 1995 Suburban - SOLD
Bodied 1995 Tahoe -SOLD
jbjburbs is offline   Reply With Quote
Old 03-07-2010, 08:45 PM   #18
jbjburbs
jbjburbs's Avatar
looks like this thread is all but dead...well hasn't been posted to in a long time. I'm in the process of bolting on a KP component's kit w/cantilever.. after talking to clint @ kp and sitting down with airride guys a show or three over the last two years i just went for it.
None of bolt holes line, but the frames (on 92-99) are close enough to work. We ended up flipping the four link mounts (more clearance) and adding a plate. I have some pics on the build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=276476
John J
