Old 01-17-2008, 07:52 AM   #1
Redneck-Mafia
Neutral safety switch, reopen a can of worms
This weekend I tackled the project to shorten the steering column to get the wheel out of my lap( I installed 99 Denali buckets with 3 point seatbelts and they are much larger than stock seats).
Ok, so the only problem I have is the NSS! The hole location moved to outside the firewall and the firewall mounting bracket goes right over the top of it. I looked at cutting a new hole and re-mounting the switch higher up the column inside the cab, but it looks like the tab the switch rides on is punched out of a piece of steel and stands up only inside the original hole.
Currently I have the NSS screwed to a piece of metal under the dash and connected to drive the truck but want a more permanent solution.
Can the switch be mounted elsewhere on the column, and how?
What years van tilt column should I look for to upgrade to tilt?
Thanks for all the great info guys. I'm sooo glad I found this site.
Dave in Socal
69 Chevy C10
42 BSA WM20
47 Harley WL
Redneck-Mafia is offline   Reply With Quote
Old 01-17-2008, 08:39 AM   #2
70GMCer
70GMCer's Avatar
Re: Neutral safety switch, reopen a can of worms
This is what I went to.......
http://store.summitracing.com/partde...5&autoview=sku
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-17-2008, 10:12 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Have you considered a floor shift and eliminating the column shifter and NSS?
piecesparts is offline   Reply With Quote
Old 01-17-2008, 12:43 PM   #4
neonlarry
neonlarry's Avatar
Why not just move the NSS ala converting a van tilt to work on a truck?
http://67-72chevytrucks.com/vboard/s...threadid=63328
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-17-2008, 01:22 PM   #5
Redneck-Mafia
Awesome stuff guys!
That's exactly the info I was looking for as far as cutting the new NSS hole.
Can anyone recommend what year(s) of van column to search for?
Thanks again,
Dave in Socal
69 Chevy C10
42 BSA WM20
47 Harley WL
Old 01-17-2008, 01:29 PM   #6
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Yep, Those are the directions I followed when I did mine. Worked out great and wasn't that hard to do!
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 01-17-2008, 03:49 PM   #7
wibilly
wibilly's Avatar
81 and older on the van tilts, 82 and up have ign switch on colume early ones have the correct wiring plug latter ones require a harnes adapter avalible at gm dealerships for about $12
common sense isn't so common anymore
wibilly is offline   Reply With Quote
