Old 01-17-2008, 08:58 AM   #1
El Bombero
El Bombero's Avatar
idles good, dies in drive???
Alright fellas, here is my newest problem. I start the truck up, (zz4/700r4), were talking a cold start here, and it idles at about 1600. Ok great. When I go to put her in drive after she drops down to about 1100, she slowly dies. I start her back up, she will idle at about 1100 for a second or two then die. I talked to a mechanic friend of mine, and he said its possible that my torque convertor could be locked up. Im stumped at this point. Later today, Im going to jack up the rear end and start her up and put her in drive and see if it makes a difference with the wheels off the ground. I will let ya know. But if y'all have any advise or have been through this, I would love to hear about it. I will be back on later and let you guys know what happened. Thanks for your time!
P.s. it got down to 40 degrees last night! so when I say cold start, take it as you will
They sure don't make 'em like that anymore
El Bombero is offline   Reply With Quote
Old 01-17-2008, 10:05 AM   #2
Luvlegs
Luvlegs's Avatar
Re: idles good, dies in drive???
It sounds more like a fuel or perhaps a vacuum (loss) issue to me.... or a sticking choke? I'm not an expert but like to think I might know where to start... Let's see what it turns out to be - good luck.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-17-2008, 10:29 AM   #3
heavy71chevy
heavy71chevy's Avatar
change the fuel filter...had the same problem recently and it was a clogged filter..also check the vacume hoses
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 01-17-2008, 10:55 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
don't bother looking at the converter... if it was that, it would slam into gear and stall instantly.
Sounds like your timing is way off to me.
Old 01-17-2008, 02:58 PM   #5
mnunn454
mnunn454's Avatar
Yeah. I agree it's not the converter.
Major vacuum leak, timing or fuel mixture way off is my guess.
Are you getting black smoke or no smoke out of the tailpipe when it dies?
Is the automatic choke stuck? Or, is it coming off too quickly?
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-17-2008, 03:07 PM   #6
joemacho
joemacho's Avatar
its sounds like your accelerator pump went bad or your floats in carb are bad.
joemacho is offline   Reply With Quote
Old 01-17-2008, 04:16 PM   #7
odog
odog's Avatar
My other vehicle, a f*rd, did that to me 3 weeks ago, after a cold night. I don't think the cold had anything to do with it, #4 and 7 plugs were fouled. Seamed to idle fine, but sputtered and died when backing up. I changed the plugs and have had no problem. Just an idea.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 01-17-2008, 06:17 PM   #8
El Bombero
El Bombero's Avatar
Well, I couldnt get to the truck today. Got stuck running errands all day. I gotta work a 48hr shift starting tomorrow. So hopefully I will have it figured out by Sunday. Thoes are all good points guys. Im leaning towards a vacum problem so far. I will keep you posted! Thanks for the help so far!
Old 01-17-2008, 07:06 PM   #9
Longhorn321
Size Matters
Longhorn321's Avatar
[QUOTE=El Bombero;2532464] (zz4/700r4
Can you give me a little more info? What is a zz4? How does the engine sound when starting? If the timing is too far advanced it may sound sluggish...If the timing is retarded, it will start easier but may have a problem when under a load (like when you put it in drive). Also, what is the maintenence history if you know? When have the plugs/points/cap/rotor been changed? When have the fuel filter/filters been changed? Gotta start with the basics...Let us know! Good luck! Dwayne
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 01-17-2008, 07:59 PM   #10
custom72c20
custom72c20's Avatar
My truck kept doing that on the way home from work and I ended up having to get towed home. When I worked on it in the morning, I took the distributor cap off and the top of my rotor was burnt to a crisp and there wasa hole in the dist. cap right below the coil.(H.E.I.) I have no idea how it happend, but it doesn't hurt to check.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
