Old 10-17-2002, 07:17 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Whats Going On????!!!!!
Yesterday after school I went to my truck, and I heard a rocker loose in the head so i took the valve cover off when i got home, found the loose rocker, tightened it, then everything was fine. THEN AFTER SCHOOL TODAY!!, I went to it and started it up and the same thing with the same rocker????!!!??? what is that??? is something wrong???
Ideas??
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 10-17-2002, 07:22 PM   #2
Zkast
Zkast's Avatar
While you have the valve cover off, lay a straight edge (or something close) across the rocker arm studs. I bet you'll find one thats pulling up on you. Each time you adjust the rocker its fine until that rocker pulls the stud up a bit more.
If this is the case, you can buy oversized studs, knock a new one in and your all set.
The other possibility is a lobe going flat on the cam which is dishing out the bottom of the lifter (causing more and more valve lash) If it's still running ok after the valve adjustment, chances are the cam/lifters are in good shape.
Zkast is offline   Reply With Quote
Old 10-17-2002, 07:23 PM   #3
bigjimzlll
bigjimzlll's Avatar
could be a couple of things...bad lifter(doubt that) rocker stud is pulled up,check the hieght compared to others or the most likely cam lobe going flat..you might want to look at the pushrod..see if the ends are messed up, also check the rocker where the pushrod goes into..if it turns out to be the cam lobe..dont drive it ...the cam guts do very bad things to bearings
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 10-17-2002, 07:25 PM   #4
bigjimzlll
bigjimzlll's Avatar
boy zkast..you sure are smart....lol.. we must of posted at the same time
Anderson,CA
Old 10-17-2002, 07:25 PM   #5
Zkast
Zkast's Avatar
lol same answer at almost the same time
Old 10-17-2002, 07:29 PM   #6
Alaskan
Truck'n the alcan
Alaskan's Avatar
Could be a couple of things. Rocker stud is sliping, bent push-rod, collapsed lifter. I'd bet it's a pulled rocker stud. To check lay a straight edge on the top of the studs.
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 10-17-2002, 07:31 PM   #7
Alaskan
Truck'n the alcan
Alaskan's Avatar
Must be some fast fingers out there. All good advise.
68 GMC 4x4
Old 10-17-2002, 08:37 PM   #8
JDL
JDL's Avatar
it might be just a bad nut that works its silf lose
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 10-19-2002, 03:24 PM   #9
Jwill41
Jwill41's Avatar
i had an old pontiac one time that i had to replace the nuts on the rocker arms. no problems after that. i think they are tapered nuts and after a few times on and off they dont stay tight any more.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
