Old 01-17-2008, 02:10 PM   #1
baggedcten
86 C10
baggedcten's Avatar
Bagged Guys did y'all have to notch cab?
im going to four link my truck and wanted to know if yall had to notch the cab for the one peice drive shaft. Pics would be great thanks.
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 01-17-2008, 02:22 PM   #2
JayG
Formerly ADHDCARGUY
JayG's Avatar
Re: Bagged Guys did y'all have to notch cab?
I'm not 4 link, mines ladder bar with a 2" notch. When it is sitting on the bump stops, I've about 1 1/2' clearance between the cab and the drive shaft and my cab mounts need to be replaced which might give me another little bit! But I've a 9" and I don't know if the drive shaft might be higher in Chevy rear in relation to the axle center line.
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 01-17-2008, 04:34 PM   #3
bedsled71
bedsled71's Avatar
i had to notch my cab about 2 inches.. the back part hangs down so you can cut that without cutting into the support brace under
bedsled71 is offline   Reply With Quote
Old 01-17-2008, 06:36 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
Dino's 78 lays frame hard with NO cutting to the cab. You will have to notch the crossmember behind the cab. It's running a Dropmember and a KP six-link.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-18-2008, 01:58 AM   #5
baggedcten
86 C10
baggedcten's Avatar
Was Dino's truck a one piece drive shaft? I remember his truck badazz
1986 C10
Old 01-19-2008, 01:31 AM   #6
baggedcten
86 C10
baggedcten's Avatar
I've searched couldn't find out.
1986 C10
Old 01-19-2008, 03:57 AM   #7
Kontrol Phreaks
Kontrol Phreaks's Avatar
With out 73-87 4 link kit you get the new driveline crossmember notch included. None of out customers have had to notch the cab while running a one piece driveline. The Porterbuilt truck Nathan was refering to has our complete rear suspension kit installed on it, and it lays hard on 22's.
On this truck, the drive line notch was welded and smoothed in.
This truck has the notch simply bolted in as the kit was designed with the no fabrication .
There's plenty of room between the cab and driveline.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 01-19-2008, 04:00 AM   #8
Kontrol Phreaks
The back of the 67-72 cabs are totally different from the 73-87 trucks. On the early trucks the frame kicks up right behind the cab, and the cab is lower on the chassis as well. The later (73-87) have those body mounts that really space the cab up over the frame, and they don't have that large pinch that hangs down either. ..... Lucky dogs .
- Clint -
Old 01-19-2008, 04:11 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
As Clint mentioned, Dino's 78 does have a one-piece drive-shaft. The Dropmember moves the motor and trans up a bit, so we had to make our own notch for the drive-shaft in the crossmember behind the cab... to make a little more room! Still no cab cutting!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-19-2008, 06:29 AM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I Luv the look of that Blue frame, who's toy is that on?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-19-2008, 08:47 AM   #11
baggedcten
86 C10
baggedcten's Avatar
Do y'all sell the drive line crossmember seperate? If y'all do how much would it cost?
1986 C10
Old 01-19-2008, 02:02 PM   #12
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I had to cut a little bit out of my floor (right after the transmission) under the seat for the drive shaft to clear. motor in stock location.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-20-2008, 02:14 AM   #13
Kontrol Phreaks
That truck belongs to my buddy Jim Cunningham out here in Cali. We're hoping to finish it up soon and get it driving to the shows over the next few months. He recently moved and we have to get the shop back in order and start making some noise.
- Clint -
