Old 01-17-2008, 06:13 PM   #1
Weezer67
Crossmember installation
I am in need of some clarity. I have a 67 chevy short stepper frame that I am working on. It is a leaf spring set up- 6 lug with a dana rear end. I removed the dana and purchased from Randy a 71 front crossmember complete and a trailing arm frame from a pre-71. The front member is going well but I read that I need 8 grade bolts. Is that corrrect? Any other tips that you could share?
Back to the rear...I cut out the rear crossmember with the trailing arms and I have the crossmember for the spring perches. My big debate is, do I convert to the trailing arm set up or just use the leaf and put the rear on it. The truck will be a nice driver, nothing more. And finally, is it easier to have the axles drilled to the 5 on 5 or are new axles a better option. I read that if you drill a 6 drum axle you have to machine the hubs for the drums? (?) Also how do I tell the machinist what I need?
Any imput from you master fabricators would be greatly appreciated. I value your experience.
Weezer67
Dodge City, Kansas
Weezer67 is offline   Reply With Quote
Old 01-18-2008, 12:05 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Crossmember installation
I have some input on the leaf vs coil/trailing arms.
I own one each (GMC & Chevy) and never noticed much difference in the ride when I drove them in town. Some swear by the coils for smooth driving, though. The other thing that I would think about is the simplicity of the spring vs. the trailing arms when it comes to parts replacement.
68gmsee is offline   Reply With Quote
Old 01-18-2008, 01:22 AM   #3
1969K10
1969K10's Avatar
FWIW, I much prefer leaf spring set-up to the coil set-up. I feel that it is more stable as far as keeping the tires in contact with the road.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-19-2008, 03:55 AM   #4
Weezer67
68gmsee and 1969K10. I appreciate you taking the time to give your imput. I guess I'm a little puzzled why I couldn't get a few of my questions answered from all the great builders on this board. I guess I'll just wing it...not what I wanted but oh well...
Weezer67
Dodge City, Kansas
Old 01-19-2008, 04:03 AM   #5
70C10Step
70C10Step's Avatar
I am swapping over from leafs to coils also. Yes it is worth is you want the ease of lowering your truck and adding bags later... I have gone through this debate and I have decided to go to coils for ease of lowering and making suspension adjustments...
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 01-19-2008, 04:39 AM   #6
greasy68
greasy68's Avatar
I have leaf springs and recently considered switching to trailing arm suspension. It's a bit expensive if you buy a CPP or ECE setup that includes the crossmember and the whole deal. I think the ride with leafs is good enough for me to just keep it but I agree with 70C10Step that if you are going to lower it you should go with the trailing arms.
Yes, You should use grade 8 bolts for the front.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 01-19-2008, 04:51 AM   #7
70C10Step
70C10Step's Avatar
I was fortunate enough to find a parts truck for my swap. There are some board members with these parts for sale at a decent price...
All Toys:
Old 01-19-2008, 10:07 AM   #8
corn
I find when someone suggests to use grade 8 bolts, I usually just use them. I cant see why you would need to on a crossmember but the cost difference wont break you on a piece like this. A leaf or coil debate is something I dont want to join in on, both have advantages & disadvantages. I wouldnt really say its more work to bag a leaf truck than converting to coils & then bagging it too...
corn is offline   Reply With Quote
