01-17-2008, 08:39 PM | #1 |
Tire/wheel size
Hey guys i have a 68 LWB with everything stock and i am switching to 5 lug and need new wheels. I am going to runs 15's but would really like to know how wide i can squeeze into the stock rear wheel wells. backspacing? tire size? any help is much appreciated/needed. Thanks
11-08-2009, 08:30 PM | #2 |
Re: Tire/wheel size
I would be interested in this as well
11-08-2009, 08:45 PM | #3 |
67-72 parts collector,…
Re: Tire/wheel size
Depends on which rearend you are using. 63-70 with different 5-lug axles or the wider 71-72 5-lug rearend. This will affect you backspacing measurement.
11-08-2009, 09:22 PM | #4 |
sharp as a marble
Re: Tire/wheel size
Lolife, could you give us a backing plate to backing plate measurement for both rear ends. Thanks
11-08-2009, 09:38 PM | #5 |
Re: Tire/wheel size
I ran this set up on my 1972 rear end...........
Front: 15X8 4.0 BS 245/60 15 Rear: 15X10 5.0 BS 295/50/15 Let me know if you're intersted in these ralleys |
11-08-2009, 09:39 PM | #6 |
Re: Tire/wheel size
I have a '69 6-lug rearend that measures 55.5" from backing plate to backing plate.
The 71-72 are 3/4" (per side) wider. So that would make the 71-72 rearends 57" from backing plate to backing plate.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-08-2009 at 09:42 PM. |
11-08-2009, 09:40 PM | #7 |
Re: Tire/wheel size
11-09-2009, 12:38 AM | #8 |
Re: Tire/wheel size
I fit 13.5 inch wide slicks on mine, but wasn't low enough to tuck
