Old 01-17-2008, 09:15 PM   #1
soba_03
soba_03's Avatar
Question How about a little heater help?
Ok folks,
It's a 68 C10 307 auto. The heater worked perfectly earlier this year and fan was great, super strong. Now that it MUCH colder it seem that I can't get the blower out of low. It just barely blows. The heater switch is find and the levers and bushings are in tact. I can run a hot wire to the blower motor and it seems like it works perfectly. However when using the blower lever and the standard truck wireing it only blows low.
I suspect that it's the little spring (temp sensor) mounted in the heater duct behind the glove box. I can't think of it's corrct name right now.
Ok what is it's purpose? Can I bypass this "thing" and make the blower work on high and adjust my heat output with the levers? Just wondering. Tired of every night after work getting into a really cold truck and waiting forever for it to blow enough to clear frost and fog off the window.
Yes the coolant level is correct and the thermostat is correct as well.
Any help would be wonderful.
Thanks...
soba_03 is offline   Reply With Quote
Old 01-17-2008, 09:33 PM   #2
mrein3
mrein3's Avatar
Re: How about a little heater help?
I think the "spring" thing you are referring to is the resistor block. It drops the voltage to your fan, reducing fan speed. Take a look at the wiring behind the controller. A lot of times the wires melt down. Get a wiring diagram and make sure all the wires work as designed.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-17-2008, 09:45 PM   #3
soba_03
soba_03's Avatar
"Resistor" Ok i' assuming you mean the one that mounts in the heater duct?
I have chcked the wireing at the switch and ran all the dash and heater wiring and can't locate a problem. IF the reistor is bad I'm assuming that it could create my problem? Like I said jumper to the blower runs it at full speed. I'll look inot it further.
Old 01-17-2008, 09:46 PM   #4
brak
brak's Avatar
I would agree. it's most likely the resistor.
it's an easy replacement, only 2 screws (iirc), and it only costs about 10 bucks.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 01-17-2008, 09:55 PM   #5
soba_03
soba_03's Avatar
It my own fault, this summer I R/R the heater core and found that the resistor that was in the truck was bad and I threw in one I had picked up at a yard that was used. I guess that it's time to stick a new one in there and go from there. I just wasn't sure if there was any mods to this in an attempt to eliminate maybe a weak link.
thanks..
Old 01-18-2008, 05:20 AM   #6
soba_03
soba_03's Avatar
Ok I guess that this thing isn't as easy to find as I thought. tried a few local shops and they looked at me as if I had a third eye.
I did check out Chevy Duty web site for it but didn't locate it through there website. Who has purchased one and from where?
Thanks.
Old 01-31-2008, 07:42 PM   #7
brak
brak's Avatar
I purchased one last winter, either from chevy duty, or GMC paul's.
EDIT--->
the resistor is P/N 363040 ($12) on GMC Pauls website.
it's on the main page of the Heater & A/C section
Old 02-01-2008, 02:16 AM   #8
chris71
chris71's Avatar
are you sure that the fan switch is not the problem?i would think that is the problem. if your fan switch goes, you will have no high speed, if your resistor goes you will have no low speed. i had the same problem, no high speed on the fan, replaced the fan switch ($12 from LMC) and problem solved. whatever you do good luck.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 02-01-2008, 03:20 AM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Wink Re: How about a little heater help?
Problem sounds like the resistor, some parts houses can still get it but they actually have to look for it. I'll see if I can get the 4 Seasons part # for you.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-01-2008, 03:36 AM   #10
Firefighter
FSE #20906 about any halfway intelligent parts guy can cross that number!!
Yellville, Ar. USA
Old 02-01-2008, 04:23 AM   #11
Kager67
what knocking sound?
Kager67's Avatar
I agree with chris71. The resistor is there to give you your low fan speeds. Without that your fan would blow on high all the time. I would check your switch. JMO
kage
1968 C-10
1953 belair two-door post
1955 chevy 3600 big window
1950 studebaker starlite coupe
1968 Impala SS
Kager67 is offline   Reply With Quote
Old 02-01-2008, 05:41 AM   #12
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Check the relay its what controls the high speed.
sneakysnake is offline   Reply With Quote
Old 02-01-2008, 05:55 AM   #13
67chevemall
67chevemall's Avatar
bypass the ford parts and just run it on high or off.
$0.02
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-01-2008, 09:09 AM   #14
Hutch
Hutch's Avatar
soba_03
Check the ground wire that is on the relay harness behind the glove box.
It is mounted up high
Symtoms on the fan switch are
low = low
med = medium
high = low
The ground wire (black) goes from the relay harness to the firewall and gounds on one of the heater box studs.
You can jump a ground for a test.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 03-17-2008, 02:26 AM   #15
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
I'm having the same problem with mine. Do you have a pic of where that ground needs to be on the realy?? It looks like it doesn't have a place or plug, but the wiring diagram looks like it just screws to one of the mounting screws.
jayharrell is offline   Reply With Quote
Old 03-17-2008, 06:20 PM   #16
soba_03
soba_03's Avatar
Jay,
Here is what I found on mine. The blower switch would only operate on low. I ordered a resitor however had it fixed before parts arrived. I found that the switch on the heater control wasn't making good contact. So I added a little dielectric grease to the pins and changed out the reistor any way and it works fine. I'm told that for some reason the wireing at the heater control tends to over heat and melt. Mine was fine but that is what I was told. I found that connections were a little dirty and not making good connection so cleaned those up and works good. Actually the ground is actually on one of the heater box mounting studs. Hope you get it worked out. If your flow still remains low and you haven't pulled your fan and heater core out ever. You might consider pulling it out and cleaning out the years of debris that collect in the heater area.. Mine worked fine, had to change out heater core and removed a mouse nest ot two now it will part your hair when it's on defrost..
Old 03-17-2008, 06:54 PM   #17
jayharrell
jayharrell's Avatar
Thanks for the info. It was the ground. I hooked one up from the monting screws on the relay to the firewall and bam-o. Worked exactly right. Thanks for the help
