Old 01-18-2008, 05:50 AM   #1
andy mc
what rear end
Hey guys been a while. I did a search and could not find anything that I understood. I have a 70 chevy sb and wanted to know if there was newer rear w/ posi that I can use.Thanks, Andy Mc
andy mc is offline   Reply With Quote
Old 01-18-2008, 07:11 AM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: what rear end
What do you mean by "newer”? Later model? if so I would have to ask why? These rear ends come in Posi and can be built good and strong. You can go to a F@rd 9" or anything as far as that goes if you want to spend some $$. I had currie build me a F@rd 9" but that’s what I wanted. Unless your planning BIG HP the stock rear-end done up right should be fine.
Just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-18-2008, 07:47 AM   #3
Re: what rear end
Hey Andy,What rear do you have,a 12-bolt w/coil springs?If so,what gears?
Newer rears will all be leaf spring.You can change spring mounts.One shock mount needs moved on`73-up.But,you could use any 12-bolt.
You can change the gear ratio,rebuild,install a posi,install disc brakes,or anything you want with the rear you have.
Got more info?
Old 01-19-2008, 06:10 AM   #4
andy mc
Re: what rear end
Thanks for the info guys.I sold my original coil spring rear, before I thought what else I was going to use.Don't expect to have but about 375-400 HP.Just wondering what newer (lim-slip or posi) would bolt up easy without a lot of work or bucks. Andy Mc
Old 01-19-2008, 10:39 PM   #5
jkade
jkade's Avatar
Re: what rear end
If you have to buy wheels get you a 8.8 from a explorer or have the axles redrilled to 5on5
jkade is offline   Reply With Quote
Old 01-20-2008, 06:47 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: what rear end
why not go with a 12 bolt from a 67 - 72? It'll bolt right in, and 400 horse is nothing unless you install tires that'll bite real hard.
Old 01-23-2008, 06:08 AM   #7
andy mc
Re: what rear end
Thank guys,
No I don't have wheels yet.Guess I need to figure out what option is cheapest/easiest/best option.
