LWB Club
Winshield Wiper ARM removal??
OK, I am stuck! How do I remove the wiper arms? Looks like there is a little pin that slides forward but that's all I can see.
Help! Ps. And that's "Windshield" not "Winshield" LOL
72 Chevy Custom LWB Last edited by 72ChevyAZ; 01-18-2008 at 07:37 AM. |
Old Skool Club
![]() Join Date: Jun 2001
Re: Winshield Wiper ARM removal??
I have a tool that I bought from NAPA, that lifts the arm off of the post. It's like a pair of pliers in one respect, but they lift and separate, instead of squeeze. Geeze, sounds like a bra, but it ain't.
They'll set you back about $10, and save you from a lot of fussin' and cussin'.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Old member
On a 71 you can buy a wiper tool that clips over the arm to thwe head and hold the arm and tool together and wiggle it right off.
Not sure about your model but I think you have to pull the side of it out to unclip it. It's like that for some models but don't know when it started. Here is one. I got mine at Advance auto. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Active Member
![]() Join Date: Jul 2007
Again, not sure if they changed them in later years of you have had newer style arms installed, but on both my 68 and 69 I lift the arms as high as they will go and then pry the bottom up.
I use a heavy cloth (towel or even a leather glove) on the cowl to keep from damaging the paint and gently pry up with a claw hammer. I've even wrapped the hammer claw with a shop towel. |
![]() Join Date: Jan 2007
![]() I was a bit confused the first time I pulled mine, but with the proper location and just enough force a towel oh the hood and a pry bar in the right spot (very bottom exactly opposite wiper arm portion) it will come right off. It took a bit of force my first time (I didn't want to break anything) - and it just popped right off. |
Firefighter
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
The Older Generation
I just priced these at NAPA. they were $16.... Bottom arm is plastic coated to protect paint but I think I would still use a folded rag.
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-18-2008 at 11:52 PM. |
