![]() Join Date: Sep 2001
Question about heater control cables...
how the heck do I route them? They're stiff as he'll. The long one (heat) is easy, but the middle one is bound up where it goes past the dash vent hose.
This is a non-ac truck.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
The Older Generation
Re: Question about heater control cables...
Are you sure you have them routed correctly? Here is a link to a thread on it. You need to lube them before you install them too. http://67-72chevytrucks.com/vboard/s...=heater+cables LockDoc
yep, I lubed them up before I installed them. I ran them the same way as in the pic too, and they work fine, but I had to bend that middle one around slot to get it to reach. I also had to wrestle with the vent hose, so I got to thinking it was wrong.
