01-19-2008, 08:31 AM | #1 |
Active Member
Another crossmember ?
OK, First let me say I have read all the crossmember posts I can find. I have decided to section my crossmember 1 1/2". I was also thinking of moving it forward maybe 1", If I do that the steering box will need to move also and the idler arm or what ever it is called on the other side. When I am moving these items forward does anyone see any reason why I can't go up also like maybe 1/2"? this would solve a couple of clearance isues, Like tierods and steering shaft. I would love to here your comments before I get that far.
Thanks Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
01-19-2008, 02:04 PM | #2 |
It'd be alot cooler if you did
Re: Another crossmember ?
you have to move the steering components up the same amount as the crossmember other wise you change the steering geometry and it will bump steer like hell.
01-19-2008, 05:28 PM | #3 |
Speaking from experience, I would highly recommend you save yourself a lot of hassle and go 1 1/8"
01-20-2008, 01:05 AM | #4 |
I don't know how he's arriving at this number, but I can tell you FROM EXPERIENCE that raising it 1.5 inches leaves surprises around every corner!
01-20-2008, 01:42 AM | #5 |
I agree 100%.
01-20-2008, 02:06 AM | #6 | |
What if you live on a corner and do it in the garage ?
- Clint - |
01-20-2008, 08:30 AM | #7 |
belly dragger
I went 1 1/2 then I put in a 1/4 spacer made life alot easier.
SAVE THE PLANET DRIVE AN OLD TRUCK |
01-20-2008, 09:15 AM | #8 |
Active Member
Thanks everyone. I wanted to move crossmember forward to center tire in wheel well but looks like next to impossible with stock steering. With 1 1/2" section where is the rub? the lower a-arm u bolt? Thanks for everyones help.
Jack
01-20-2008, 10:40 AM | #9 |
belly dragger
My tie rods rubbed on the crossmember.
01-20-2008, 03:04 PM | #10 |
X2. Crossmember lip & the nut for the lower a-arm outside u-bolt.
01-21-2008, 12:50 AM | #11 |
I arrived at that number by "being there, done that." I sectioned mine 1.5, and like others, ended up putting a 1/4" shim on it. I still had to shave a lot of the crossmember so the inner tier rods would not hit the x-member. I also cut down the u-bolt for extra clearance.
01-21-2008, 12:52 AM | #12 |
belly dragger
You should probably move into the garage and stop living on the corner
